81 intermittently won't start
Old Aug 10, 2013 | 09:31 AM
pops1863's Avatar
pops1863
2nd Gear
Default 81 intermittently won't start
Hello,
My car intermittently will not start after. There is no clicking..no starter turning over... just dead. After it sits awhile, it will turn over and start. Any ideas where I should start?
Old Aug 10, 2013 | 10:13 AM
7T1vette's Avatar
7T1vette
Ignition switch, neutral start switch, or starter solenoid are the most likely suspects. Use a voltmeter to see if those items are transferring voltage, as they should, when activated.
Old Aug 10, 2013 | 03:26 PM
terry82's Avatar
terry82
check connection behind passenger side head .it is 5 or 6 wires that go down to the starter.those connections go bad .
Old Aug 10, 2013 | 05:21 PM
scorpion18z's Avatar
scorpion18z
Check out my thread, "Can You Identify These Components?" in General forum
Old Aug 10, 2013 | 06:59 PM
LannyL81's Avatar
LannyL81
Check battery cable connectors on both ends of the cable. Also could be the thief deterrant system.
When the engine does not turn-over are you unlocking the door with the key? Do not reach in through an open window and unlock the door; the alarm should go off, but perhaps it is not but the ignition interrupt relay is working....which opens the current going to the starter.
Do any of the dash lights come on? Gauges spring to life when you turn the key ON?
To 81 intermittently won't start
