Air cond compressor
Old Aug 11, 2013 | 10:40 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
Default Air cond compressor
Have my 75 with a stock air condition system, has not worked it 15 years or so, had it recharged and worked great for two weeks. The compressor is leaking, can see the green dye with a black light and yellow glasses.
Options?
Cost to rebuild compressor?
Get a replacement compressor?
Or just ignore it and keep driving it?
Old Aug 11, 2013 | 11:17 PM
lars's Avatar
lars
2 options:
Replace the front seal and bearing, or buy a rebuild and swap it out. I've done it both ways. If you have the tools to do the front seal & bearing pull, you can do it yourself. After having done it, I found that it wasn't worth my time to do it for the cost of the rebuilt, so the next one I did I simply swapped out.
Lars
Old Aug 12, 2013 | 10:27 AM
Ely's Avatar
Ely
You didn't mention where the compressor is leaking. Is it leaking here?
Note the dye, just to the right of the cap in the center of the photo and to the left of the ground wire.
Does anybody know if this possible leak is easy to fix?
Is it just circlip removal and "O" ring replacement?
Old Aug 12, 2013 | 09:35 PM
Mod75's Avatar
Mod75
Mine is leaking at the front by the pully, will check again before i decide which way to go on the repairs.
Old Aug 13, 2013 | 09:41 PM
gcusmano74's Avatar
gcusmano74
You can find a rebuilt A6 compressor from your local auto parts guy, NAPA or even somebody like RockAuto, as well as any of the restoration houses. (Willcox, Zip, etc.) You need to match the pulley size- I think your car will take the larger (5 3/4") pulley.
Old Aug 13, 2013 | 10:02 PM
Mod75's Avatar
Mod75
Originally Posted by lars
2 options:
Lars
Thanks Lars i was thinking the same thing, will just swap it out with a rebuilt unit.
Old Aug 13, 2013 | 10:14 PM
Bob3700's Avatar
Bob3700
Lars,
Do you know if the compressor is SNed or any specific numbers that match it to a specific year?
I too have the original compressor on my car. Have not run the system for several years but there was no damage when I quit using it. Assumed the same thing as you, change the front seal and bearing due to age.
Thoughts?
Bob
Old Aug 14, 2013 | 09:09 AM
Ely's Avatar
Ely
I believe that you need eather an R4 or an A6. I thought that both would work. The R4 is the shorter of the two. It is the one that I have posted above. My mechanic told me that the longer A6 was the more robust unit. I can't comment regarding that.
The R4 was std. in my '78. I think that he longer A6 was for later models.
Old Aug 14, 2013 | 09:34 AM
MrJlr's Avatar
MrJlr
Me personally, I went the Sandon route. Light-weight, R134, almost NO engine drag.
Old Aug 14, 2013 | 02:04 PM
Ely's Avatar
Ely
Fancy... Shinnie. Like the chrome look.
Old Aug 14, 2013 | 08:53 PM
gcusmano74's Avatar
gcusmano74
GM used the Frigidaire A6 compressor from about the early sixties to the mid 70's across all their product lines. At the time, it was considered the best in the world; Rolls Royce would buy them to install in their cars.
Old Aug 14, 2013 | 09:58 PM
Ely's Avatar
Ely
Thanks for the clarification.
So… the A6 was the forerunner to the R4.
Old Aug 14, 2013 | 10:01 PM
joerob727's Avatar
joerob727
Hey MrJlr,
That looks great, in fact I have been looking to do the same conversion on my '75. Not so much for the bling but rather for the weight and efficiency.
Did you piece the conversion or use someones 'kit'?
Thanks in advance for your time.
Old Aug 14, 2013 | 11:54 PM
sweeet76's Avatar
sweeet76
MrJLR, I used the same Sanden and love it. One of my better choices in part
replacement.
Bill
To Air cond compressor
