No Spark any thoughts?
Old Jun 29, 2002 | 09:22 PM
xfactor974's Avatar
xfactor974
Default No Spark any thoughts?
I've got a HEI distributor that I got from Advanced auto parts last year that isn't putting out any spark. The distributor is new, i just got a coil and put that on. That didn't work. I bought a cap and rotor and that didn't help. Think that it's the ignition module? I'm not sure what else could be going bad in an HEI. The motor is a '76 by the way. :D Thanks for the help guys.
Old Jun 29, 2002 | 09:28 PM
BeachinVette's Avatar
BeachinVette
Default Re: No Spark any thoughts? (xfactor974)
Check to see if you have 12vdc going to the Dist. That is the only thing I can think of.
Bob
Old Jun 29, 2002 | 10:35 PM
Corvette Cowboy
If not the module, could be the pick-up. Look for a broken wire at the pick-up. It is a common problem with HEI.
Old Jun 30, 2002 | 12:40 AM
xfactor974's Avatar
xfactor974
Default Re: No Spark any thoughts? (Corvette Cowboy)
I got it! I had power to the coil, that wasn't the problem this time. The problem was that the rotor I just put on there a month ago had lots of carbon on it. I wire brushed it and it fired right up. Go figure? Why do you think that the rotor is getting carbon buildup on it so fast?
To No Spark any thoughts?
