sidepipes
Aug 13, 2013 | 11:24 AM
sidepipes
need help!!!! what is the best way to cut out the tac welds in the side pipes to get out the r flow. glass packs, to put in sts baffles? ray
Aug 13, 2013 | 05:32 PM
Quote:
Originally Posted by
rays699
Dremel?
Aug 14, 2013 | 12:42 PM
normally they are not welded in, remove them by dropping open end on a piece of soft wood
Aug 15, 2013 | 11:40 AM
pipes
MelWff
these are tac welded in hard to get to the welds where the true out is no room for a die grinder or dremel .
Aug 15, 2013 | 12:25 PM
Aug 15, 2013 | 04:47 PM
Well you can always buy replacement side pipe sections without any mufflers installed...
Aug 21, 2013 | 07:53 AM
rays699
Did you get them out? If so how? Any damage to the pipe? I'm in the same spot.
Aug 27, 2013 | 11:09 AM
sidepipes
RDCRIS
got one side done, die grinder open end, dremel with flex shaft at turn down end. and a lot of cutting wheels + TIME, this is a bitch, but worth it, new xs power ss 321 side pipes. 3" wheel on die grinder + 1 1/2 wheel on flex shaft
Aug 27, 2013 | 12:06 PM
I tried with a dremel also. Pain in the ***. Could not get the ones at the exit side. So I said f**k it and ordered another set of pipes.
Aug 27, 2013 | 12:14 PM
RDCRIS
any problem can be solved by throwing $$ at it!!
Aug 27, 2013 | 02:31 PM
isn't that the truth
Aug 27, 2013 | 05:53 PM
Royal Canadian Navy
Glad I bought the Hookers.
Aug 27, 2013 | 06:13 PM
resdoggie
i hope your wife doesn't find out.
Aug 27, 2013 | 08:09 PM
Royal Canadian Navy
****, I was havin' so much fun with my Hookers I forgot about her!
