Rally wheel codes.
Old May 1, 2003 | 06:03 PM
DaBo's Avatar
DaBo
Default Rally wheel codes.
I know that the list of codes has been posted before, but I have searched...RALLY...RALLEY...& RALLYE in the CF archives and for whatever reason cannot find the info.
Would some one PLEASE!!!! post the list of codes again for me.
THANKS!!!!
:cheers: :cheers: :cheers:
David
Old May 1, 2003 | 09:02 PM
goinbroke's Avatar
goinbroke
Default Re: Rally wheel codes. (DaBo)
The 69 thru 82 steel rally wheels ( 15X8 ) are stamped with the letters AZ to the right of the valve stem. The 68s are 15X7 and stamped AG I beleive....not sure about 68s. If you're looking to buy used rally wheels be advised......there are Camaro rallys that are very similar to the C-3 wheels. They are 15X7 with a 4 1/2" backspacing ( vette is 4") and are stamped FW.
[Modified by goinbroke, 8:18 PM 5/1/2003]
Old May 2, 2003 | 03:52 AM
DaBo's Avatar
DaBo
Default Re: Rally wheel codes. (goinbroke)
:cheers:
Cool...Just picked up an extra set of "AZ's" this afternoon.
Old May 2, 2003 | 03:13 PM
goinbroke's Avatar
goinbroke
DaBo, just curious where you got them and what they cost. Those suckers are hard to find. I got 4 at $50 each at a vette salvage yard near Waco Texas. They needed cleaning and painting, but otherwise in good shape.
Old May 2, 2003 | 03:20 PM
DaBo's Avatar
DaBo
I guess I did well then......
I bought the 4 wheels (no rust, need cleaned), nice center caps, decent mismatched trim rings, and Sumitomo tires with less than 1500 miles for $250.00.
Old May 2, 2003 | 03:48 PM
goinbroke's Avatar
goinbroke
Yep, sounds like you got a good deal.....especially since you got tires and rims. The first place I tried (not the place in Waco) was kinda goofy. I called ahead to make sure they had the correct rims since It's a pretty long drive. After I got there the guy hauls out 4 rims.....they didn't look quite right...sure enough they're stamped FW. I tell the guy they're not vette rims.....he says oh yes, they came off a vette. I tell him these are Camaro rims. After 45 minutes he finally comes out with 3 rusted up C-3 rims and wants $55 each. I tell him no thanks...
:cuss
Old May 2, 2003 | 06:30 PM
mxzx turbine's Avatar
mxzx turbine
okay guys how can you tell 69 wheels from 79 steel wheels, i refinished the wheels that were on my 71 and then thought i'll check the codes, the stamping reads as follow K18 12 20 AZ, are these 69 AZ ot 79 AZs
Any input appreciated
mxzx turbine
:party:
Old May 2, 2003 | 09:35 PM
goinbroke's Avatar
goinbroke
Default Re: Rally wheel codes. (mxzx turbine)
As I had it explained to me....all 69 thru 82 rallys (15X8) were stamped AZ. I think I read somewhere that the smaller stamped numbers and letters can be decoded to find the year of mfg, but am not sure of this. I've looked close at the Camaro and Vette rallys and both start with a K in small stamps. Hopefully someone can chime in and educate us on what the small stamps mean.
Old May 2, 2003 | 10:19 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
:party:
The break down of wheel codes goes like this. The K stands for Kelsey the manf. The 1 stands for the manf plant. The 8 stands for the year (1968 or 1978). The 12 stands for the month (Dec). The 20 stands for the day of the month and the AZ is the size code used on corvettes.
The correct year code for a 71 would be a 0 or 1, 1970 or 1971 depending on the build date of your car.
Hope this helps.
gq
Old May 2, 2003 | 10:24 PM
mxzx turbine
Default Re: Rally wheel codes. (gq82)
I hear ya, but the wheels I have are either 68 or 78 manufacture date, I would like to figure out which one, I have another set of correct 70 manufacture date wheels for my 71,
[Modified by mxzx turbine, 1:38 AM 5/6/2003]
Old May 5, 2003 | 07:53 PM
DougsL89's Avatar
DougsL89
If your wheels are K-1-8 AZs, then they are 1978 8" wheels. I just decoded my wheels this weekend, and alas, they are non-original 8 inchers (K-1-5, K-1-6, K-1-0 AZs). Unfortunately, I had a chance to buy a set of 7 inchers (AGs), and I told the guy no because I thought I had mine!
Old May 5, 2003 | 08:01 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
Default Re: Rally wheel codes. (DougsL89)
I also believe K-1-8 AZ wheels COULD be '68 dated wheels. Early '69 Corvettes MADE in '68 will have '68 dated "AZ" wheels on them.
Old Aug 26, 2013 | 06:24 PM
Wahooboy3000's Avatar
Wahooboy3000
2nd Gear
Default AZ Rally Rims
I have had a set of Corvette Rally Rims sitting in my basement for 20 something years. I got this code from them:
K 1 6 10 19 AZ. From reading on this forum, am I correct in translating this to Oct. 19 1976? Is there any chance that these are 1966 rims? Thanks very much!
Rob
Old Aug 27, 2013 | 03:20 PM
Gale Banks 80''s Avatar
Gale Banks 80'
I'n answer to Your question 1969 or 1979 there is no way to tell which one by looking at the Date Codes or any other marks. Same for 70-80, 71-81,72-82. The later Cars had diffrent Trim Rings wich would be a dead give away, and so many ( most) late cars were deliverd with the optional Aluminum Wheels that most likely the wheel in question would be the early one.
Old Aug 27, 2013 | 03:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Wahooboy3000
...Is there any chance that these are 1966 rims?...
No. No Corvette rally wheels in 1966.
FWIW: this thread is ten years old.
Old Aug 27, 2013 | 03:39 PM
Wahooboy3000
2nd Gear
Thank you so much EM! Old thread, but the info is still fresh So now at least I know what I have.
Thanks again EM & Corvette Forum!
Old Aug 27, 2013 | 08:30 PM
Gale Banks 80'
There were Ralley Wheels made in 1966, but there were no 15 x 8 Wheels till 1969, which were Corvette only.
To Rally wheel codes.
