Carbotech performance Brakes
Old Aug 13, 2013 | 11:36 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default Carbotech performance Brakes
We don’t just sell you a set of brake pads; we deliver unmatched customer support and technical help. Carbotech Performance Brakes are also leading the way with Pro, Grassroots and Track-Day/HPDE groups and drivers. We can help you find the perfect set up for your vehicle by having an entire line up of street and track compounds for your application. Contact info is below if you need some help or would like to order a set. Orders place direct through me receive 5% forum discount.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Aug 30, 2013 | 09:54 AM
Carbotech Adam
Supporting Vendor
Old Sep 6, 2013 | 12:37 PM
Carbotech Adam
Supporting Vendor
Old Oct 14, 2013 | 10:47 AM
Carbotech Adam
Supporting Vendor
From street use to the higher performance demands of track days, we'll help you achieve better brake modulation, torque and fade resistance. High-tech construction means better stopping power and a higher level of driver confidence every time you get behind the wheel.
Old Oct 30, 2013 | 11:16 AM
Carbotech Adam
Supporting Vendor
Carbotech brakes utilize a ceramic and metallic construction in a range of compounds that out-perform competitive brakes. Carbotech brakes are made from compounds that offer higher initial bite, torque and fade resistance—providing consistent brake modulation and performance over a wide range of operating temperatures.
Old Nov 20, 2013 | 03:21 PM
Carbotech Adam
Supporting Vendor
I will help you determine the perfect brake pad compound for your car and your style of driving. Carbotech brakes are designed to allow you to “Go Deep!” while being particularly rotor friendly and contain 100% non-corrosive brake dust.
Old Nov 20, 2013 | 03:33 PM
hugie82's Avatar
hugie82
Give us some prices Adam. Maybe some pics of what you have for C3 corvettes. You got an UN heard of 19 year run of the same brakes system so lets see what you got instead of the sales pitch
Old Nov 20, 2013 | 03:58 PM
Carbotech Adam
Supporting Vendor
We our not the cheapest brake pad on the market but, I will give you what we have compounds and pricing. We do offer 5% discount for forum members. We our a small brake pad mfg based in Concord, NC all our products are 100% made in America and we own our own compounds and they are mixed and molded in North Carolina.
Carbotech™ 1521™
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Carbotech™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1100°F + (10°C to 593°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. AX6™ offers high fade resistance, rotor friendliness at all temperatures and excellent cold stopping power. As a result, AX6™ is an excellent choice for Autocross and has gained tremendous popularity with SCCA Prosolo/Solo2 competitors for its outstanding all around performance. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn't recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as race compounds in most applications. For application questions please call or email Carbotech™.
Carbotech™ XP8™
A high torque brake compound with a wide operating temperature range of 200°F-1350°F+ (93°C to 732°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Excellent as a front brake pad for lighter applications weighing around 2,400lbs or less. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
Carbotech™ XP10™
When Carbotech™ unleashed the XP10™ to the general public it was an instant success. XP10™ immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite friction material with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1650°F (898°C). Due to the high level of friction and bite, this material is recommended for cars weighing around 2,900lbs or less. XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP12™
Another highly successful XP™ series compound with an excellent initial bite, torque and fade resistance over and above the XP10™ compound. XP12™ has temperature range of 250°F to 2000°F+ (121°C to 1093°C+). The XP12™ has that excellent Carbotech release and modulation that has made all other Carbotech compounds so successful. The XP12™ is more rotor aggressive than XP10™, but compared to the competition the XP12™ is still very rotor friendly. XP12™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP16™
Carbotech™ XP16™ is a step up from the highly successful XP12™ compound. With an aggressive initial bite, torque and fade resistance, and higher than our XP12™ compound. XP16™ has a temperature range of 250°F to 2000°F+ (121°C to 1093°C+). Carbotech™ XP16™ has outstanding release and modulation that has made all other Carbotech™ compounds so successful. The XP16™ is the most rotor aggressive compound from Carbotech™, but compared to its competition the XP16™ is still very rotor friendly. Carbotech™ XP16™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP20™
The latest iteration of the highly successful XP™ series of compounds. XP20™ is a step up from the highly successful XP16™ compound. With an extremely aggressive initial bite, the most linear torque curve to date and excellent fade resistance the XP20™ leads the highly successful XP™ series line of compounds from Carbotech™. XP20™ has a temperature range of 275°F to 2000°F+ (135°C to 1093°C+). Carbotech™ XP20™ maintains our tradition of having the outstanding release and modulation that has made all other Carbotech™ compounds so successful. The XP20™ as with other Carbotech™ compounds is very rotor friendly. Carbotech™ XP20™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Carbotech™ RP2™
The RP2™ compound was engineered for endurance racing based on our highly successful XP™ Series formulations. RP2™ is our longest lasting compound that we offer. RP2™ has strong initial bite, a little less modulation than our XP12, but still maintains the rotor friendliness of our XP™ series compounds. With a good initial bite and one of the most consistent torque curves in the market the RP2™ compound is easy to keep a consistent bite and torque throughout the braking zone. Great fade resistance with a temperature range of 250°F to 1650°F+ (121°C to 898°C). RP2™ is as rotor friendly as our XP™ series compounds. Carbotech™ RP2™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Corvette - C3
1968-1982 Front CT8 & Rear CT8
1521 AX6 XP8 XP10 XP12 XP16 XP20 RP2
$139 $156 $171 $188 $207 $224 $242 $224
Corvette - C3
1965-1972 J56 Package F: CTJ56
$168 $185 $200 $216 $233 $251 $272 $251
To Carbotech performance Brakes
