C3 headlight issue "again"
Old Aug 13, 2013 | 11:38 AM
ostateborsch's Avatar
ostateborsch
8th Gear
Default C3 headlight issue "again"
I have a 1980 and the right light went up but had to pull the left up and they both went down, now, neither go up I have to pull them up but they both go down when I pull the manual ****, with the manual **** up I cant even pull the lights up, what do you think the problem is?
Thanks to all who reply
George
Old Aug 13, 2013 | 12:14 PM
7t9l82's Avatar
7t9l82
wilcox i believe has a good diagram of the system, it actually isn't that complex. a hand vacuum pump will help you diagnose your problem.
Old Aug 13, 2013 | 12:46 PM
ostateborsch
8th Gear
thank you for your quick response
Old Aug 13, 2013 | 04:57 PM
redman76's Avatar
redman76
St. Jude Donor '09
I had to troubleshoot each component and ended up replacing/repairing everything . . . headlamp switch, check valve, relays, actuators and most of the vacuum lines. It's easy to test with a hand vacuum pump. I found this information useful:
http://www.corvette-101.com/vacuum.htm#tools
http://forums.corvetteforum.com/c3-t...ay-valves.html
http://forums.corvetteforum.com/c3-t...tem-works.html
Old Aug 14, 2013 | 10:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the vacuum relays to each headlight first.
To C3 headlight issue "again"
