engine swap questions
Old Aug 16, 2013 | 11:04 PM
mvette76's Avatar
mvette76
Default engine swap questions
will a 454 with a rpm intake fit under a 75 hood with a drop base air cleaner
Old Aug 17, 2013 | 12:40 AM
John 65's Avatar
John 65
Yes, it will.
I have a 77 with a 454 in it with a 750 Holley under my stock hood.
Pretty sure its the same as a 75 hood.
Old Aug 17, 2013 | 07:20 AM
oldschoolvette's Avatar
oldschoolvette
it should that being said be careful when you go to shut the hood the first time.
I am very familiar with what happens if you don't
that's also why it is a good idea to not do the final paint until after all the mechanical is done
unless you just need more practice fixing your hood
I did
To engine swap questions
