80 brake bleeding procedure
I THINK its:
LR inner
LR outer
RR inner
RR outer
LF
RF
Anyone ?
Cant find it on Wilcox or VPB sites ...nor a search here.
thank you in advance.
The strategy is to be certain that you get all the air out of the system by:
Bench-bleeding the master cylinder-lots of air in the piston pockets; if you don't get that unit free of air to begin with...forget it.
LF, get air out between M/C and LF;
RF, get the rest of the air out of the front brakes system.
LR/inner, M/C to LR;
LR/outer, rest of left rear set;
RR/inner, ditto RR;
RR/outer, complete the system.
This process "chases" any trapped air from the system [closest to farthest], rather than assuming that all the air in the system gets removed by doing the RR/outer bleeder to start. {not a good assumption, at all}
RR/inner, ditto RR;
Have gravity flowed each port, now waiting on my buddy to get home to do the real bleeding.
Thanks for your replies !
The Chevy Chassis Service Manual states that you should use a rubber mallet and "bash" (my term, not their's) the caliper while bleeding it. I usually bleed the brakes, then drive it a few days to see if there is any spongy feel to it. If there is, I'll re-bleed them a few days later. Driving the car tends to jostle any trapped air and get it to where the bleeder can let it out at the next attempt.
When my wife came home she helped me by being the brake pedal buddy. Went off like a charm.
While I waited, made a vacuum canister to pull the fluid from the caliper end thru the system. That worked great too.
If anyone is interested in seeing my contraption ,drop me a pm . It was a 20 oz glass jar, metal lid that I brazed 2 fittings on. 1 was for my vacuum pump, the other a brake fluid hose that attached to the caliper. Only problem was: using 3-5 inch vacuum, you pull air in from the bleeder threads and can be misleading that the air seen is air in the lines.
Good way to pass a couple of hours making the thing. lol
The 80 brakes are like new now.
Worked for me last time I did it.
