A/C Switch on the Accumulator
Old Jun 30, 2002 | 02:16 PM
virtue4u's Avatar
virtue4u
Default A/C Switch on the Accumulator
I can get the compressor to "click" on only if I by-pass the switch on the accumulator. Do I need to replace the switch? And if so, can it be removed without losing refrigerant? I know I am low on my refrigerant charge, but shouldn't I hear at least one "click" from the compressor before the switch cuts it off? Or will simply filling up the charge without removing the switch make the compressor finally click on. By the way, this is an R12 system.
Old Jun 30, 2002 | 03:13 PM
8T1-7T9 BIONIC VETTE's Avatar
Default Re: A/C Switch on the Accumulator (virtue4u)
virtue4u,
I don't know the answer, however I'm interested in what others have to say.
I'll be interested in knowing how this works myself.....I just switched from R-12 to R-134. Since then my compressor continues to click on (idle rpm drops), click off (idle rpm increases)...this happens every 45 seconds or so....I'm sure it's not supposed to cycle that many times in such a short period of time. Could it be a faulty switch?....Can this be changed or adjusted by me?.... :seeya Cappy
Old Jun 30, 2002 | 03:34 PM
virtue4u's Avatar
virtue4u
Default Re: A/C Switch on the Accumulator (8T1-7T9 BIONIC VETTE)
Dear Bionic Vette,
I know the answer to your problem. The reason your compressor keeps switching on and off is because it is low on refrigerant. A switch designed to keep the compressor from ruining itself clicks the compressor OFF when it is low on refrigerant. Since you already converted over to 134a, all you need to do is charge it up again by buying a can of refrigerant. The bigger question for you is where did your refrigerant go? IF your leak is bad, you need to find the leak and correct it.
My problem (I think) is electrical or maybe I am so low on refrigerant that my compressor won't even go on (but I doubt that I wouldn't at least hear one click); however, I don't want to waste a can of expensive R12 trying to find out the problem. I need someone to help.
Old Jun 30, 2002 | 10:47 PM
mark79,80's Avatar
mark79,80
Try pulling the connector from the accumlator switch and jumping across
it. The compressor should start and run. Hook up a set of gauges
to the AC lines. If the low side pressure is below 30 pounds with
the compressor running, the system is low on refrigerant.
As someone else said, the switch is activated by pressure. It is designed
to keep the compressor from starting if the pressure is low.
If the pressure is low, would leave the connector jumped as freon is added
to keep the compressor running.
Old Jul 1, 2002 | 02:38 AM
slide's Avatar
slide
Default Re: A/C Switch on the Accumulator (mark79,80)
I just charged the A/C in my 75 and it had been totally discharged, after the first can of refridgerant was consumed the compressor kicked on. So it dosen't take much pressure to activate the switch.
Old Jul 1, 2002 | 04:44 AM
virtue4u's Avatar
virtue4u
Dear Mark and Slide,
I already jumped the switch and the compressor comes on fine. I have about 100 pounds in the system when it is static. You may be right that the compressor will work just fine when I add a can; I just thought with that much pressure, I would get at least one click before it would switch itself off. I hate to put a can in the system to test it out, but unless someone has any better ideas, that may be what I should do.
Old Jul 1, 2002 | 05:47 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Virtu4u
The switch is designed to cycle the compressor at 18 to 20 psi, at this pressure using R-12 the evaporator coil temp. will be about 32 degrees if it is allowed to get below this the condensate will freeze on the coil and restrict the air flow. The port that the switch is screwed onto was equipted with a schrader valve in it. You schould be able to unscrew the low-pressure control switch without any loss of freon and replace it with a new one. When you replace the switch I would suggest replacing it with the car running and with the a/c on this way if the schrader valve fails the pressure in the system will be around 30 psi and not 100 psi. The only drawback to this is if the system is low of freon it will be operating in a vacuum on the suction side of the system and if the schrader valve has failed the system will draw air into it when you remove the low-pressure switch. If you have a set of a/c service gauges, bypass the low-pressure switch and check the pressure on the suction side with the system operating, and the car at idle, if the pressure is above 5 psi on the suction side you should be allright.
Be careful my 77 has a high pressure cut off switch it looks a lot like the low-pressure switch, but it is not mounted on the accumulator. Hope this helps.
Old Jul 1, 2002 | 09:20 AM
virtue4u's Avatar
virtue4u
Default Re: A/C Switch on the Accumulator (chevymans 77)
Dear Chevyman77,
Yes, that does help, but I still have a question. With 100 psi in the static condition, shouldn't I get at least one click of the compressor if the switch was functioning? I know I'm low on freon (probably two cans), but with that kind of static pressure on the low side shouldn't the compressor initially kick on before the low side pressure falls to the point where the switch (if working properly) would shut the compressor down?
Old Jul 1, 2002 | 03:27 PM
chevymans 77
Yes any pressure over 18 to 20 psi on the suction side, static or with the system runnig should close the switch and engage the a/c compressor clutch, if the switch is operating correctly.
Old Jul 2, 2002 | 10:08 AM
virtue4u's Avatar
virtue4u
Still more problems. I can get the compressor to come on if I bypass the switch. I installed a new switch and freon, but I still cannot get the compressor to click on. The switch is in a tight place and may be under some physical stress against the fender when I plug it in, preventing it from working correctly. Tonight I am going to run wires from the switch to the plug or install an elbow from the accumulator to get the switch more out into the open. If that does not change anything, then I will try one more can of freon. If none of the above works, then I will concede to paying a mechanic. It just bugs me because I know its something simple.
Old Jul 19, 2012 | 09:52 AM
bj6762's Avatar
bj6762
I see two things here. Compressor click on and off constantly: Most GM's are CCCS systems. aka: Constant Cycle Clutch System. Designed to function that way.
Secondly: If you jumper (the plug in wires, together) going to the low pressure switch and compressor kicks on; freon is low. 12 and 134 work the same. on pressure.
Also I have installed new & rebuilt compressors many times. Be sure to check the air gap between the pulley and the outer clutch plate. Varies from .19 to .27::: Magnetic power can only reach so far.
Old Jul 19, 2012 | 10:31 AM
'75's Avatar
'75
You brought up a 10 yr old thread, they have likely figured it out by now.
Old Jul 19, 2012 | 10:39 AM
bj6762's Avatar
bj6762
Ok. Can you tell me how much time and instruction on how to change my vir accumulator on my 76? I'm handicaped but willing to try.
Bill
Old Jul 19, 2012 | 10:49 AM
'75's Avatar
'75
I applaud your can do attitude, however, changing the VIR is challenging for even able bodied experienced mechanics. First the refrigerant would need to be recovered, then the hard part is breaking the lines loose from the VIR, they can be corroded in place. Other than that, just the mount screws and it's out of there. You can gain some access from underneath by removing the lower access panel behind the right front inner fender.
Old Jul 19, 2012 | 10:54 AM
bj6762's Avatar
bj6762
I'm a stroke survivor. Lost most use my left side. Used to be a mech. Still have soom tools and a grandson. How about the fan shroud? I bought a new one.
Bill
Old Jul 19, 2012 | 11:03 AM
'75's Avatar
'75
Man you really know how to pick them. The fan shroud is probably one of the more frustrating jobs also. Is it the early or later design? On the early design, there is an extension for the shroud and not on the later. I remove the radiator on my 75 (same as early 76) and then the shroud.
Old Jul 19, 2012 | 11:05 AM
bj6762's Avatar
bj6762
Later!!!!!!!!!!!!! The exspensive shroud!!!!!!!!!!!!!
Old Jul 19, 2012 | 11:10 AM
'75's Avatar
'75
Actually on mine, I went with an electric fan and didn't put the shroud back in, it was that much of a pain.
Old Jul 23, 2012 | 01:04 PM
kansas123's Avatar
kansas123
Sorry to have to ask, but I can't remember where you jump, from A to B, A to C, or B to C where the thermo heat limiter switch goes..... thanks.
To A/C Switch on the Accumulator
