PLEASE HELP Modded 81
Old Aug 19, 2013 | 09:21 PM
stick21's Avatar
stick21
6th Gear
Default PLEASE HELP Modded 81
this is driving me nuts has anyone changed out the carb intake dist
on a 81 corvette??
all the lines were taken off the fuel vapor can and the gas smell is unreal in my garage
The can has 6 outlets fuel line in
air vent line looks like I can get into the back top of the carb bowl
The carb is a holley spreadbore model # 80555-1
I have no purge valve in the thermostat housing
I can T the pcv coming out of the bottom of the carb
no egr valve
so that leaves me with 1 hose 5/16 and 1/4 hose what do I do with them ?
and have many of these hoses do I have to hook up to make it work and can I just plug the others
I assume I need a the vent and pcv hooked up right?
any pictures would be great
thanks
Old Aug 19, 2013 | 09:24 PM
stick21's Avatar
stick21
6th Gear
Old Aug 20, 2013 | 06:28 AM
Jig A Low's Avatar
Jig A Low
the easiest bet is to disconnect the line that comes from the fuel tank to the charcoal canister and put a rubber cap on it. the canister may smell like gas for a while but with the line comming from the tank capped it will evaporate out of the canister eventually.
To PLEASE HELP Modded 81
