306 in c3?
Old Aug 20, 2013 | 10:51 AM
Planbmatt1's Avatar
Planbmatt1
Default 306 in c3?
My friend is selling is fully built roller 306 engine. its in a manual so my questions are this
Will it work in an automatic?
What parts would i need?
Also can a 306 be put in a c3 corvette easily?
What parts would I need to make it fit?
Thanks as I know nothing about engine mounts and if engines can be interchangeable from auto to manual
Old Aug 20, 2013 | 10:54 AM
TedH's Avatar
TedH
Do you mean a 305? 307? Same exterior dimensions as a 350 so all mounts and transmission will line up. No issue that it is from a car with manual trans as automatic trans mounting does not affect the engine. I think 305/307 are internally balanced like 327 and 350 so the auto trans flex plate for the transmission should be fine.
Old Aug 20, 2013 | 11:00 AM
Planbmatt1's Avatar
Planbmatt1
Sweet! He Is in my car group so he is gonna sell it for literally the price of an aluminum head
Old Aug 20, 2013 | 11:07 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Well, it depends on what engine it is based on and the bore/stroke ratio. If it is an overbored 302 then it will be peaky without the low end torque that a heavy C3 needs to get moving unless you change the rear end ratio to something lower, like a 3.73 or a 4.11. That sucker will buzz at 60 MPH. You need more details before you pull the trigger on that one. It could easily be a dog around town but a killer engine on the freeway.
Old Aug 20, 2013 | 11:21 AM
Planbmatt1's Avatar
Planbmatt1
I asked him all the details ill get back to you guys
Old Aug 20, 2013 | 11:34 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
406?? never heard of a 306.
Old Aug 20, 2013 | 11:54 AM
Planbmatt1's Avatar
Planbmatt1
Yea I know but he says its a 306. I asked him
What it is based off
Compression
Bore
Stroke
Cam
Heads
Carb
Old Aug 20, 2013 | 11:56 AM
Planbmatt1's Avatar
Planbmatt1
There Is a 306 sbc though so
Old Aug 20, 2013 | 12:23 PM
bashcraft's Avatar
bashcraft
No there isn't, and if he's telling you this, he's full of $hit.
Old Aug 20, 2013 | 12:26 PM
Planbmatt1's Avatar
Planbmatt1
Nvm its a 306 ford. Came out of a foxbody mustang and is built to roller. Will it work?
Old Aug 20, 2013 | 12:29 PM
bashcraft's Avatar
bashcraft
No.
Old Aug 20, 2013 | 12:32 PM
Planbmatt1's Avatar
Planbmatt1
Bummer thanks for the help guys.
Old Aug 20, 2013 | 01:21 PM
MrJlr's Avatar
MrJlr
Almost any engine can be "made to work".....
But that sounds like more trouble than you need.
Old Aug 20, 2013 | 01:25 PM
scottyp99's Avatar
scottyp99
Sure, you can make anything work, if you throw enough money at it. Would it be worth it? Absolutely not. Stick with a small block chevy if you want to minimize expensive headaches and hassles.
If this guy is trying to sell you a Ford Windsor engine to put in your 'vette, he may be having a little fun at your expense.
Scott
Old Aug 20, 2013 | 01:40 PM
Planbmatt1's Avatar
Planbmatt1
Lol yea i passed the offer up.
I have a performance shop in joplin called Sho me Speed who is working on a quote for me right now for two things
Nitrous kit install. I can pick up a full kit that was on a c3 corvette for $150, ( bottle warmer, bottle opener, wot switch, window switch, etc)
Top end kit install on l48
Old Aug 20, 2013 | 07:03 PM
Planbmatt1's Avatar
Planbmatt1
He also has a fully built tranny for it. So if it came with a 5 speed could it hook up to my driveshaft easily and I would just need motor mounts?
Old Aug 20, 2013 | 07:51 PM
jotto's Avatar
jotto
Easy if you have very deep pockets and excellent fabrication skills.
Way too much work and money IMHO. Walk away.....
To 306 in c3?
Old Aug 20, 2013 | 07:59 PM
Planbmatt1's Avatar
Planbmatt1
Gotcha. Ill stick to throwing a bottle on It.
Old Aug 20, 2013 | 08:02 PM
Indiancreek's Avatar
Indiancreek
Someone mentioned the .030 over boref 302. That would be around there. A 4.030 bore and a 3 inch stroke. Came in the Z28. Sound great and rpm very high. However, you'll need to keep it around the 4,500 rpm range to have power. The Zs ran well but all at top end. If you ran an auto you'll need a big number stall converter.
In a C3 it would be a dog from the sit still, unless you really gear it. Like someone said 4.11 or maybe a 4.56.
If you got it cheap enough, it may be fun to play with for a while. As a driver, I think it would get old before to long.
Old Aug 21, 2013 | 06:48 AM
bashcraft's Avatar
bashcraft
Why would someone put a Ford engine in a C3?
