I am having a hard time mounting my rear wheels. My rims are hitting the spring bolts and the spring bolts are at different angles. Hopefully these pictures help describe what I'm dealing with. I also noticed that the shock mounts appear to be at slightly different angles. I hope the pictures captured that also. I bought the leaf spring from a member on here and don't see any problems with the spring itself. Anyways, any help would be appreciated.
I posted this on my build thread but figured I might have better luck posting a separate thread.
It looks like everything is shifted to the right side of the chassis. How are the trailing arms shimmed? Have you tried measuring the frame to see if it is straight?
Well I turned the camber bolts but I still have an angle I do not like on the drivers side. I basically turned both camber bolts so that both bolt heads are to the outside. I checked the yokes and they are fine. Would letting the spring "settle" have enough effect to make both bolts perfectly vertical?
Are you sure the spring is centered in the mount? That really looks odd.
I would measure the spring length from the center to each end/bolt hole. And as Mr.Ward suggests measure everything with the suspension normalized with the car weight on the tires.
Thank you all for your input. I measured both sides and it was exactly one inch longer on the passenger side. So I scratched my head because I thought for sure the mount was centered on the spring before bolting it on the diff. I took the spring off and checked my marks and sure enough the mount had shifted during the install. The spring bolts now look correct. Thanks again!
