Oldschool Timing Adjustment
Feel free to dismiss any of my knowledge and experience in engines and engine controls, but I have a simple question: How did you arrive at the correct timing curve for your engine?
You have very specific info on all aspects of you motor and you know where you want it set....Not everyone does. If you said to me" I want this car timed at 34* then I would use a timing light as that's the only way to set and confirm a specific number.
If you gave me an car with no specifics and just said it runs like crap can you make it better, I'd start with a vacuum gauge to help check engine health, carb settings, and timing.(along with compression and leak down gauges) Vacuum will tell you where the car wants to be, and the timing light will give you what that number is. If the distributor is ever removed for any reason, then I'd have a set number for reference and would just use the timing light to get it back to that setting.
I agree timing lights are a very important tool to have. As is a dwell meter(for points cars) and a vacuum gauge. All serve their purpose, and when used together can give the best results.
Sticks and stones. Troll. Really that's the best you got. I'm guessing ur quite a bit older then me be happy a 23 year old is into vettes and will try and carry on long after ur gone no subs, Toyotas, no Hondas just my vette, if I post and you don't like it well that's just to bad.
Troll kinda has a nice ring to it
You say that you have determined the optimal timing setting using information from "piston mfg, head mfg and other knowledgeable mfg's and folks like Lars", and then you use a timing light to set your timing at that point. What you're doing amounts to making an educated guess at what the timing should be, and setting it there. With a vacuum gauge, you can actually get some feedback from the engine to see what it likes. It may not be perfect, but I think it's better than guessing.
Even Lars doesn't usually quote specific numbers when making timing recommendations, he will usually give a range. 34-38 degrees, for instance. It's up to you to tune it.
Scott
Anyway, personally, I am glad to see people your age who are into older cars like these. Just, please don't put a big, park-bench wing on the back of your 'vette, OK?
Scott
I really doesn't matter how old you are, and I really don't care. If you need help with a problem there are a lot of people willing to help, but starting off being a d-bag isn't the best way to get it.
Scott
Lars did make a comment in another post that on some newer aluminium heads that optimal timing can be reduced a few degrees for optimum performance. Others, e.g. mfg's, have also stated this. So the 36* optimum considered by most for the sbc does not apply for me as I have previously stated. Anyway, the OP asked why or why not. I said use a timing light because its more precise. Don't see what all the fuss is about, really.
It's a free country, you can set your timing any way you like, I suppose. It's starting to sound like you will not be swayed, so I guess we'll just have to agree to disagree.
Scott
Just for fun,
Connect a vacuum gauge to any non computer car so you can read it while driving.
That along with a tach, take notes of your observations at different rpm and load levels. Change your timing, drive for a few more days taking notes. Keep repeating.
Some of you guys might learn something about vacuum.
You can even do it with an FI ECU engine if it's distributor based and you move it far enough off the computer's control limits.
If you set the idle timing with vacuum, how can you be sure it´s at optimum at higher rpm´s?
Every distributor has a different advance range, so if you set it to optimum at idle, it may perform better at medium load, but may not be perfect at full load.
Setting the curve just for maximum output power could be the reason why it does not perform so good at medium load.
So I think both meanings are right.
Paragraph 7 is wrong!
About the idle mixture screws
CW= in for lean and
CCW= out for rich.
CW= in for lean and
CCW= out for rich.
Scott
Scott
Ok I hear you no wing, not my thing anyway, but I don't hate on those that like that sort of thing and neither should you or anyone else, it's a choice a personal one. I think there are a few stuff shirts on the forum and I like pulling their chains. Timing lights no timing lights vacuum timing no vacuum timing, whoa again to each own. These arguments don't produce viable factual information just opinions based on individual experiences. So really interested parties who want the information are left with a variety of choices because grown men bicker so yes sticks and stones you have to bring yourself down to their level and add a little humor, it's not a discussion in my view it's a few people posturing trying to convince the rest of us they have the right answers, I still don't have the factual information from these subject matter experts to make a decision on what is the best way to set up timing for max performance and drive ability on the street. Attack the issue not the person
Scott
It's the internet, man, you have to learn to sift through all the BS to get to the good stuff. That means using your critical thinking skills, not just parroting what you have heard others say. It's harder than it sounds, because we all do it, subconsciously. It takes a conscious effort to do your own thinking.
Scott
