Oldschool Timing Adjustment
Then again, I think I'm still learning, so maybe I just need some constructive coaching in this area. Given where I'm at now, I don't see bondoboy's questions (as many of us are just trying to learn here) as out of line.
Also, I realize than I am not the best writer and I sometimes have trouble explaining what I mean in print opposed to speaking in person. Sorry for any confusion.
Last edited by bondoboy; Aug 28, 2013 at 09:52 PM. Reason: forgot to add something
So since no one has answered your question I guess we will have to time it with a light and then see where it ends up doing it with a vacuum gauge.
The literal answer to all your questions is: It depends....Yes, you will always advance the timing, except when it's too advanced, then you retard it.
After setting it by vacuum, how much more advance do you end up with than setting it by the experts' guidelines or factory settings? Well...it depends...there's really no way to tell until you do it. You could take a guess, I suppose.
See what I mean? Think of vacuum tuning your ignition timing at idle like adjusting your idle mixture screws. Using a vacuum gauge, you adjust them to where the engine likes it. Same with timing, use a vacuum gauge to set the timing where the engine likes it, then adjust your mechanical advance so it comes in where you want it. Sorry, but there are no easy answers here, you have to understand the subject at hand in order to understand the answers. In my prior post I provided a link that should help you out.
Scott
I also took the time and interest to reply to most of the questions you posed in that post. Feel free to point out those you disagree with.
I've also spent a ton of professional and hobby time dealing with and designing engine controls, along with my share of hearing damage in engine dynos. I'm speaking from my experience in this area, and certainly not posting anything here just to "be a dick here".
example if the cam guys say between 12-14 with this cam (based on lift and duration and an educated guess) and you use a vacuum gage the check it with the light you might be at say 13 or 15.
The difference is that you are at a place the motor likes. IE your cam, heads, headers, intake and carb combo like this setting.
You are normally very close to the experts guess but this eliminates the one size fits all generality.
You just need to be careful not to go too far.
As far as advance vs retard you basically figure that out on the fly based on where you are on the curve. Normally you advance until peak and back up. If it has too much in it (timing) already the you gotta back up first (retard) and the advance to peak.
You also gotta monkey with Carb to keep idle constant or you will screw yourself (figuratively and literally)
Hope this helps
If you have specific questions send me a PM. I am a technical trainer by trade and will try and help you as much as possible.
Hope this helps
Hope this helps
And then there is advance. Obviously advance is simply the difference between initial and total but how about range in between? In other words, can you determine the best curve using vacuum? I don't mean to be critical, but it seems to me if vacuum is the best way to determine optimal timing then it should be the best way to determine the optimal advance curve. Lastly, does load affect any of this? Load certainly affects carb settings, does it affect determining the optimal timing?
Granted, dynos are great for figuring all of this out but for those of us that won't being doing any dyno tuning soon timing tricks can be great information. As for who should be the ultimate authority on all of this? I welcome comments from anyone with an advanced level of knowledge. As for who is right? That could probably only be determined by a head to head competition, and in the end the contenders would probably be so close nobody would be a clear winner, and yet any results would for sure be better than I could do. Bottom line, there's more than one way to skin a cat.
I certainly hope all of our resident experts weigh in, its an opportunity for all of us to learn and make our own decisions based on our own level of knowledge, for better or for worse.
2. all engines are different.
3. all fuel is locally blended
4. altitudes are different.
5. three of those 4 affect the way an engine runs and vacuum is affected by it, vacuum is a tuning tool and should be used in concert with other methods.
A vacuum gauge tells you what your engine likes.
I have to experiment due to crappy CA wanna-be premium, iron heads and high compression 60's engines.
Here's a post:
http://automotivemileposts.com/garage/v2n8.html
Here's 1 way:
CORRECT SETTING OF IGNITION TIMING WITH VACUUM GAUGE
Connect gauge to intake manifold. Start engine after jacking up rear wheels just off floor. Set throttle stop screw until speedometer shows 14 to 15 M.P.H., no more. Hook up Vacuum Gauge on distributor side for convenience, loosen dis*tributor lock plate screw. While watching Gauge, turn distributor body which*ever way it has to go for retard, until hand indicates 16" or 17". Then, turn distributor body in opposite direction to advance until hand reaches its highest point and begins to fluctuate ahead. Hold it at this point for an instant, then turn distributor body back again very easy, just enough to remove the bounce or fluctuation, thus causing the hand to remain perfectly steady. This is the best point of setting. Lock distributor plate lock screw on side. This allows very close ignition timing setting without "ping" or knock. A road test will then definitely prove the setting is correct.
If the motor is in perfect condition, the hand of Vacuum Gauge will remain steady between 15" and 21".
Altitude has a definite effect on Gauge readings.
At sea level, the Gauge will read approximately 19.5".
For each 1,000 feet above sea level, the Gauge will drop one inch.
Example:
At 2,000 feet the Gauge will read approximately 17.5".
At 5,000 feet it will be 14.5", and at 10,000 feet it will be 9.5".
I've always thought that setting the timing with only a light and a generic curve was quick and easy, but inefficient regarding overall engine performance (horsepower, fuel economy, drivability).
An engine dyno is obviously the most precise way to dial in the timing curve, but dyno time is incredibly expensive, and not terribly convenient for most of us. There's a couple other ways to load the engine at different speeds and loads, but they're not easily available to the average enthusiast.
A vacuum gauge will give some actual data/information to help you find the ignition timing "sweet spot" in your tune. Obviously a vacuum gauge will only give you useful data in the engine load points where there's still vacuum, but that's still a majority of the engine's speed/load curve.
