79 A/C Condenser
Old Aug 23, 2013 | 11:00 PM
g5067's Avatar
g5067
Default 79 A/C Condenser
Hope someone can help me with the number of the top and bottom A/C condenser fittings. I want to replace the original condenser with a new parallel one from Nostalgia Air Conditioning. When I called them they wanted to know the number of the top and bottom fittings. They indicated the top is usually a number 8 and the bottom a number 6, but I needed to confirm.
Old Aug 24, 2013 | 01:16 AM
oldalaskaman's Avatar
oldalaskaman
6 and 8 sounds like what they were when I converted mine to 134. I'd like to suggest that while you're doing that much work you replace both of those hoses with new, it will save you doing it twice
Old Aug 24, 2013 | 08:24 AM
g5067's Avatar
g5067
Thanks for the tip on replacing the hoses. I had not thought of that.
To 79 A/C Condenser
