Steering when engine off?
Old Aug 25, 2013 | 08:56 PM
taylor34's Avatar
taylor34
Default Steering when engine off?
I ran into this problem the other day, basically my car was dead (due to one of the battery cables accidentally working loose, which I found out later), so I tried to put it in neutral and push it out of the way...but I couldn't, because the steering wheel basically refused to turn left or right. Is there any way to steer when the engine is off? I figure that there has to be a way (or something is broke on my car), otherwise if the car died in motion you'd be totally screwed. Thanks
Old Aug 25, 2013 | 08:58 PM
wombvette's Avatar
wombvette
Yea, Its called muscle.
Old Aug 25, 2013 | 09:04 PM
taylor34's Avatar
taylor34
Huh, I knew the power steering wouldn't work and that it would be tough, but it literally seemed locked. I guess I just didn't yank hard enough. Thanks
'75's Avatar
'75
Did you have the key turned to unlock the steering?
Old Aug 25, 2013 | 09:10 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
Default steering
^ this
Old Aug 25, 2013 | 10:47 PM
taylor34's Avatar
taylor34
Originally Posted by MrForce
^ this
Yes, but it didn't seem to make a difference either way. I assume it's just some sort of mechanical lock and doesn't require battery power (since I had none)?
Old Aug 25, 2013 | 10:48 PM
taylor34's Avatar
taylor34
btw, I have a 72 if that makes any difference.
Old Aug 26, 2013 | 12:27 AM
7T1vette's Avatar
7T1vette
If you were able to put the transmission in "neutral", then the steering wheel lock was disengaged. But, to get the steering to move, you will have to get the car in motion, first. You would have to be Ahh--nold...30 years ago... to move that wheel if the car were not moving at all.
Old Aug 26, 2013 | 01:17 AM
taylor34's Avatar
taylor34
Ok, that explains it. I was trying to push the car while steering it, wasn't working, lol. Next time I'll know to turn harder, I was afraid I was going to break something.
Old Aug 26, 2013 | 06:42 AM
oldschoolvette's Avatar
oldschoolvette
these things are hard to steer with engine off but not that hard. My wife was able to steer the 78 with some effort while I pushed it. She is 5-6 and 135.
My point is that it takes some good effort but if you are ripping the wheel off maybe there could be an issue?
Old Aug 26, 2013 | 08:47 AM
Jim Shea's Avatar
Jim Shea
There is a slight amount of clearance between the locking bolt and the toothed locking plate inside the steering column head. Try rotating your steering wheel back and forth. If the locking bolt is engaging the locking plate you should hear metallic click and feel a mechanical stop as the plate stops against the bolt.
Jim
To Steering when engine off?
