'69 steering column removal question.
Thanks,
Mike
Thanks,
Mike
Once all of the bolts, (including the two lower bolts) are removed, the column will pass through the hole, it has a provision for it.
Willcox
This isn't the best drawing of the column and dash. But you can see that the hole in the dash is not round but is shaped to allow the steering column with the lever to pass through.
Jim
Thanks again,
Mike
First of all, the two columns should interchange quite easily. They are essentially the same length. But the 1977-79 column is lighter for a couple reasons:
1. Your 1969 column has a large die cast upper housing. The 1977-79 standard column head is more compact and made of plastic.
2. Your 1969 column has a shift tube and lower lever (along with a cable to connect to the reverse gear in the transmission). The 1977-79 column does not have a shift tube and does not require a cable.
A 1977 Vette standard steering column should bolt right into your 1972 Vette. 1978 and 1979 Vette standard columns (with slight modifications of the shroud that meets the instrument cluster) can also be used. Instructions for modifying the shroud are included in this paper at this site.
http://jimshea.corvettefaq.com/?p=894
You should be able to adapt your current steering wheel to the 1977-79 steering columns. You will need the following parts;
Hub Zip Products SC-414
Horn Contact (called a button stand/contact by Zip) SC-46
Screws Zip ZSC-346
Horn Button Zip SC-300
These parts should allow the 1977-79 non-adjustable Vette columns to accept the older steering wheels. (Don't go by what the parts catalogue says.)
These same parts may also be available from Ecklers and other major suppliers. However, have them cross reference to the Zip part numbers. They most likely won't recognize adapting to the 1977-79 Vette standard columns.
You will also need a turn signal lever for the correct year steering column that you are installing. Your 1972 T&T lever won't work.
Jim
I would think that a 1977 through 1982 T&T column will be somewhat lighter than your 1969 T&T. However, the non-adjustable column will be even lighter since it does not have the complexity of telescoping shafts, tilt joint, tilt lock, etc. The paper (#894) listed in my previous posting discusses installing a 1977 through 1982 T&T column in an early shark.
Jim
Jim
Edit: I need to find a fellow C3 owner with a non-t&t column to see how the wheel position feels without the adjustment capability. I don't have the wheel tilted in my car but it is adjusted all the way in for more reach (I'm on the tall side). I also need to figure out the weight difference to determine the cost/benefit ratio.
