Most likely a dumb ? but should I change to synthetic oil in my (soon to be ) '69 427? I know it runs a little cooler on syn. but am just wondering about those 60's tolerances. Weren't too good back then!! If so, what grade would u use ? I realize outside temp. plays a role here, but generally speaking.
Use of some synthetics may reduce OIL temps by a few degrees under some conditions.
So what?
If the coolant temp is being regulated by the thermostat, this minor difference in OIL TEMP has no effect on coolant temp. Even if the thermostat is wide open and no longer has influence, the coolant temp might be reduced by a degree or two.
Whoopie.
Does that result in any tangible improvement in performance or durability?
No.
99% of the people on BITOG need to get a life or at least learn to see the forest and not just the trees.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by Mike Ward
Use of some synthetics may reduce OIL temps by a few degrees under some conditions. We agree.
So what? Here's what. The oil temperature is a good indication of the rotating parts' surface temperatures and contact friction. Lower oil temp generally means that the metal being lubricated is at a lower temperature.
If the coolant temp is being regulated by the thermostat, this minor difference in OIL TEMP has no effect on coolant temp. The heat in the oil has to go somewhere, and that is to a good degree (no pun intended) into the block and head surfaces, which then conduct that heat into the coolant. But coolant temperature is not a complete description of what's happening. Remember that two engines/radiators can have the same temperature, but drastically different BTU creation/dissipation due to horsepower or internal friction. Even if the thermostat is wide open and no longer has influence, the coolant temp might be reduced by a degree or two. That agrees with the OP's comment, hence his statement wasn't false.
Whoopie.
Does that result in any tangible improvement in performance or durability? That wasn't the OP's question.
No. I disagree. Better flow, particularly during start-up and cold starts reduces wear on engine components. Better lubrication the rest of the time reduces wear and extends engine life.
I guess I'm in that one percent (an engineer here) that sees both the forest and the trees. We can have a spirited discussion on the magnitude of the reduction in heat produced using synthetics due to better lubrication, but there is no argument that reduced surface/component temperatures occur when lubrication is improved.
"I disagree. Better flow, particularly during start-up and cold starts reduces wear on engine components. Better lubrication the rest of the time reduces wear and extends engine life. "
But the OP made no mention of these attributes, whether they be true or not. Is there any proof that C3 engines last longer when operated on synthetics?
No.
Panhead59here is my 2 cents for what it is worth. If you go to a synthetic oil you have to let it warm up good and not make a habit of short drives. I say that because I have personally seen an engine that started out new on synthetic oil and changed every 5 thousand miles but he only drove about 6 miles to work and 6 miles home every day.After 3 1/2 years the engine was gone due to sludge caused by not having the oil get warmed up enough to and from work. He never drove the truck other than that. That tells me in a car I take to car shows or local events in the summer a few miles away will not benefit and might even hurt your beloved rides engine. I use a good conventional oil with a ZDDP additive in mine....just saying.
But the OP made no mention of these attributes, No, you did, and I answered your question. whether they be true or not. Is there any proof than C3 engines last longer when operated on synthetics?
No.
Proof regarding C3 specific engines? Probably not, because C3 production ended before synthetics were easily available and affordable. But how much critical difference is there between a C3 engine and a C4/C5/C6 (and I assume C7) engine, where synthetic oil was installed at the factory? Basically, not much. A C3 engine is not worlds different in materials and construction than current production engines, and I expect the reduced wear trend with synthetic oil to directionally follow that of newer engines.
Outta time, heading out to the garage to work on the '69. I'll check back later to see what further disagreements you have with synthetic use in our antiques.
Why are you specifically addressing synthetic oil, when short drives are a problem for any engine, regardless of the type of oil used?
No disagreements other than disputing any blanket claims that they provide any tangible benefit. 'Leaps tall buildings' or similar as an advertising claim doesn't mean much to me. People have been using synthetics in these cars since the 70s. That's plenty of time to accumulate data.
Having said that, people are free to spend as much money as they like on oil believing that it will make a difference.
Wooooaa. I figured I would start something. Zinc seems to be the major component missing (largely) from todays modern oil. Add the zinc and keep it clean seem to be the answer. Duh. Everyone agree on that? (synthetics must have zinc already)
Read the sticky by "540 Rat" at the top of the page. BTW less friction = less heat. However, friction at the bearings contributes less heat than combustion. Will the engine run cooler, likely not. Will the oil remain cooler with synthetic, if it is good quality oil, likely a little.
Wetter water or any coolant additive will work better at keeping temps down
Synthetic will work a little but almost not noticeable. My Harley dropper less than 5* ,I would say closer to 3*.
Just because its synthetics doesn't mean there is suffecient zddp in it to protect these older flat tappet engines.
Most off the shelf synthetics have no more zinc and phosphorus suffecient than conventional dino oils.
For your setup I would look into Brad Penn oil. Many racers and street car guys have had very good luck with this stuff.
Not necessarily. Some do, most don't. Just buy and oil that already has a sufficient amount as per the stickies. Buy the fancy boutique oil if it makes you feel better, your car couldn't care less.
Can you tell me why most, if not every manufacturer of high performance vehicles puts synthetic oil in their engines? (Or in your opinion why they're apparently wasting their money doing that?) Even Chevrolet, traditionally the epitome of tightwad manufacturing, has put synthetic oil in the Corvette for over two decades. Chevrolet rarely, if ever, spends extra money on something unless there's a compelling reason why. What do you think their reason is?
Actually, yes I can. The reasons are well documented and easily demonstrate why these same oils are of no tangible benefit in C3 engines, or any Gen 1 SBC or BBC for that matter.
The specific reasons why GM very reluctantly switched to use of synthetic (specifically Mobil1) on one C4 engine option and did not exercise a superior engineering solution is quite enlightening.
Surely BITOG must have covered this a thousand times, no?
Your wasting your breath with Mike. You could trot out all the engineering studies, argue that all the same size molecules are better at reducing friction than multiple sized molecules, show proof that viscocity breakdown is drastically reduced, show solid proof that cold start wear is drastically reduced, show that thermal breakdown is drastically reduced, show that viscocity modifiers are not even needed if the molecule is designed correctly. You can show him wear studies in direct comparison that in taxi fleets and over the road truck fleets over millions of miles long term wear is reduced over 50%, You could quote hundreds of tribologists, lubrication engineers and the engineers that design Porsche, Ferrari, Mercedes, Lamborghinis, and even Corvettes that will only warrantee their vehicles with specific synthetics. You can do all that with documented proof to back it up and he will still say your wrong and he is right.
