Salisbury MD
Old Sep 5, 2013 | 07:20 AM
4 speed's Avatar
4 speed
Default Salisbury MD
anyone in the area or passing through heading to OC vette week.
that would stop by and listen to the sound my rear is making.
I am only about 5 mile off rt. 50
Old Sep 5, 2013 | 08:37 AM
7t9l82's Avatar
7t9l82
would a proctologist be better?
Old Sep 5, 2013 | 09:02 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Or a dietician? Sorry, I couldn't resist...
Old Sep 5, 2013 | 09:13 AM
moosie982's Avatar
moosie982
What sort of noise is it making & when ? Is it coming from the differential or from the axle stubs. Possible that maybe the posi clutches are chattering when you turn left or right ? Maybe all you need is a complete fluid drain and change with the proper additive . Other then that,,,,,,good luck. Peace,,, moosie
Old Sep 5, 2013 | 09:22 AM
CaseyJones's Avatar
CaseyJones
To be serious for a change, Moosie is right. Most of the real differential noise can be cured with a fluid change with new posi additive. U-joints typically "clunk" or have a rattling noise if they are worn but a posi unit needed fresh fluid can shake the whole car particularly when going around a curve as in at a traffic intersection. It can feel like you are driving over something. A rhythmic whine can be old differential fluid or a bad bearing in the differential or at the trailing arm. Can you describe the noise?
Old Sep 5, 2013 | 09:57 AM
7t9l82's Avatar
7t9l82
fluid change for the car doctor visit.......
you would be amazed how much simple maintenance will fix. if that doesn't work post a video.
Old Sep 5, 2013 | 10:10 AM
hugie82's Avatar
hugie82
the clunks and bangs from old diff oil can get pretty loud in a parking lot at full steering lock.The clutches load and unload with a bang and the posi additive smooths that out. But a whirling or steady rumble noise is bearings, an oil change might quiet it down if the damage isn't too bad
Old Sep 5, 2013 | 12:55 PM
4 speed's Avatar
4 speed
ok. I had added posi lube, but never changed the fluid/oil I'll give that a try.
there is a video in my other post
http://forums.corvetteforum.com/c3-t...nts-video.html
I was going to say "I promise I don't have gas!"
Old Sep 5, 2013 | 01:34 PM
CaseyJones's Avatar
CaseyJones
I saw that video earlier. I still think your outer u-joint or the outer retainer is bent, broken, or not seated correctly. Disassembly required to inspect and repair. I'm sure that causes a mean vibration at speed. Not to mention the stress is puts on the trailing arm bearings.
Old Sep 5, 2013 | 03:43 PM
4 speed's Avatar
4 speed
Casey,
what are you calling the outer retainer, is this the hub and outer u-joint asemmblely,
if so, thet were not seated properly, I have cleaned and reassembled driver side. and the shake/jump/thump is still there with just the one side together.
To Salisbury MD
