Help with vibration????
Old Sep 5, 2013 | 08:46 AM
Scootin_Z's Avatar
Scootin_Z
Default Help with vibration????
Hi all,
69 4 speed car. I have a pretty noticeable vibration that comes in at about 55-60 mph and is really only noticeable under load (accel or decel) and then about 80ish it will somewhat fade out but it's still there. Just cruising it;s not so bad but I step in it at all I feel it. Where would I begin? Definitely feels like driveline. U joints? what do I look for if I get under there?
Thanks!
Old Sep 5, 2013 | 08:51 AM
Revi's Avatar
Revi
To start with, I'd jack each wheel off the ground and check to see if there is any play in the wheel bearings/ball joints.
Old Sep 5, 2013 | 09:14 AM
Scootin_Z's Avatar
Scootin_Z
Will do. Not too many miles since a frame off, but ya never know. I did notice that the drivers rear wheel is a bit on a angle compared to the passenger. I have seen this on C3's before. It's not severe and the car drives straight as an arrow. But I did notice it the other day when I was looking from behind it...
Old Sep 5, 2013 | 09:26 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I've read somewhere on the forum about drive line vibrations in the earlier C3's. It seems like the drive shaft needed to be balanced or was out of phase (slightly off relationship angles between the transmission and differential). A forum search for the might be helpful.
Old Sep 5, 2013 | 09:35 AM
Scootin_Z's Avatar
Scootin_Z
I was thinking of taking the driveshaft and half shafts off and taking them to a place here that all they do is drivelive stuff (including balancing) and see if they were out of wack. That's what it sure feels like. It comes right thru the floor of the car...
Old Sep 5, 2013 | 09:47 AM
CaseyJones's Avatar
CaseyJones
I would say drive shaft first. The length of it and the rotational speed compared to the half shafts would create the harmonics you are experiencing. Half shafts turn slower and the vibration would be more isolated unless you had a bad or misaligned u-joint.
Old Sep 5, 2013 | 09:50 AM
brennano1's Avatar
brennano1
I had a similar problem in my old camaro. It ended up being the U-Joints. Not sure if that will translate to a C3 corvette but your description of the issue sounds exactly the same. It happened near my shift points when accelerating and de-accelerating.
Old Sep 5, 2013 | 05:06 PM
Scootin_Z's Avatar
Scootin_Z
Yeah pretty much the same here. Drives me nuts sometimes...and whats strange is it seems to be worse at times. No idea why....
Old Sep 6, 2013 | 12:00 AM
croaker's Avatar
croaker
Good luck. I bet it's not the drive shaft,but keep us posted I've been chasin a vibration for a while now.
Old Sep 7, 2013 | 09:35 PM
Scootin_Z's Avatar
Scootin_Z
Really? What are you thinking yours is now? Well I am planning on a 5 speed for the car this winter so if it is in the trans that will solve that. I know it's not motor. It's only at like 55-70 under acel or decel...and it's still there a bit at say 75-80 but barely...
Old Sep 7, 2013 | 10:41 PM
toyvet1's Avatar
toyvet1
I fought a vibration for years. Ended up being the bushing in the tailshaft was getting eaten up by a bad yolk. Check for movement where yolk enters the back of the trans
Old Sep 8, 2013 | 12:40 AM
Scootin_Z's Avatar
Scootin_Z
Thanks, I will do that. Gotta get it over to my buddys lift hopefully next weekend. Would love to find it because other than that this car is AWESOME to drive!
Old Sep 8, 2013 | 08:43 AM
learje's Avatar
learje
my car had, and still has a vibration issue...heres what ive done
i changed all the u joints right after i purchased my car since i had to drop the rear end anyways to fix a yoke issue. afterwards the vibration was a bit worse. i didnt get the correct rubber mount for the front of the differential with my u joints, so i didnt replace it for the first drive. when the diff mount arrived i changed it and the vibration was noticeably better. i read up here on driveshaft angle & alignment - figured what the heck - ran down to NAPA and grabbed a new rubber tranny mount. pulled the old one, measured both...the new one was 1/8" taller. installed the new one and 80% of my vibration was gone. now theres just a slight vibration when cruisin that passengers in the car dont even feel.
my next step is to install the middle exhaust bracket which was missing when i bought the car. this will lift the tranny another 1/8" or so, and hopefully bring everything into correct alignment
ive done the angle measuring and i knew my tranny needed to come up a bit. i dont remember how to take the measurements though. i found it all here searchin
hth
Old Sep 8, 2013 | 09:04 AM
Scootin_Z's Avatar
Scootin_Z
so I'm wondering if from age the traine sits lower on the mount from the age of the mount? I'm assuming angles should be pretty straight going from the trans to the differential....
Old Sep 9, 2013 | 04:34 PM
SLVRSHRK's Avatar
SLVRSHRK
I had similar vibration in my driveline as well. The below article does a good job of explaining how to do the alignment. Fixed my issue, which was in the 60-70 MPH range.
http://www.hurst-drivelines.com/file...roc_111606.pdf
Old Sep 14, 2013 | 10:38 AM
Scootin_Z's Avatar
Scootin_Z
Thanks for the link SLVRSHRK! I will check this out...
Old Sep 14, 2013 | 01:04 PM
Solid LT1's Avatar
Solid LT1
hth
Did you read the one posters comments about a bad tail housing bushing in a transmission? I think your missing something here......
To Help with vibration????
Old Sep 14, 2013 | 02:31 PM
learje's Avatar
learje
yep, i have rebuilt my muncie, replaced the bushing and the worn yoke. didnt have any significant effect on my remaining vibration.
Old Sep 14, 2013 | 02:32 PM
Surfer69's Avatar
Surfer69
Same problem here and new tires got rid of it. Spent three years chasing it around all the mentioned areas above.
Old Sep 14, 2013 | 02:45 PM
Scootin_Z's Avatar
Scootin_Z
I have brand new hoops on it (BFG Radial TA's) and when I coast or maintain speed it's smooth as butter. It only accel or decel and at higher speed, so I know it's in the drive line somewhere....
