AC Issue
Old Sep 6, 2013 | 08:01 AM
eot52's Avatar
eot52
Default AC Issue
1970 Vert. I have a dilemma. Rebuilt compressor. Stayed original with R12. Replaced heater control valve as it wasn't staying shut allowing coolant to run through heater core when AC Controls were set on Max.
New heater control valve still not closing.
My air out the passenger vent is still about 10 degrees above what the manuals say it should be which if you are in Oklahoma like I am is huge.
I've read the posts on installing a shutoff valve in the heater line. Certainly an option.
May be a vacuum issue? Should the valve be working at idle or do the RPM's need to be greater than idle to make the valve close?
Thanks in advance for any advice or assistance!
Old Sep 6, 2013 | 10:08 AM
gerry72's Avatar
gerry72
The valve works at any engine rpm. The vacuum for all accessories using vacuum (wiper door, headlights, hvac) is supplied by a buffer tank tucked away on the right fender. You can test the valve with a hand-held vacuum pump to see if the problem is the valve or your vacuum supply.
Old Sep 6, 2013 | 10:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by eot52
...New heater control valve still not closing...May be a vacuum issue?...
Control valve opens and closes with vacuum. Do you have vacuum on at the supply line to the valve?
The AIM has a diagnostics page in the C60 options section which might be helpful in chasing down the problem.
Old Sep 6, 2013 | 12:08 PM
boat196's Avatar
boat196
Have you checked the seal around the two lines on heater core were they pass thru the A/C Heater Housing. And the damper door at passenger side cowl. Which closes when the A/C is on.
Bob
Old Sep 6, 2013 | 03:34 PM
eot52's Avatar
eot52
Just got my AIM manual yesterday and still trying to get familiar with it but will try to find the page. Thanks!
Old Sep 6, 2013 | 03:43 PM
eot52's Avatar
eot52
I tested the valve before I replaced it. Now to located the buffer tank. Maybe it's the vacuum supply? How to test?
To AC Issue
