Intermittent no start
Old Sep 8, 2013 | 09:27 PM
85camarocrazee's Avatar
85camarocrazee
Default Intermittent no start
Kind of a bit weird-when I turn the key to start position the e-brake light comes on, also i have no heat/ac blower or wipers. Everything else electrical seems to be working. However when the car is acting right and starts as it should, the blower motor and wipers work as they should..... Any ideas?? Ive tripple checked all grounds....
Edit, car is a 78 L48
Old Sep 8, 2013 | 10:24 PM
TimAT's Avatar
TimAT
Check the connector for the starter extension harness. (I know I sound like a broken record- but I've seen way to many failures). Just to the right of and behind the distributor. Plastic 6 way connector.
Old Sep 9, 2013 | 01:19 AM
wombvette's Avatar
wombvette
Wipers and heater blower has a common ground. Black wire to the starter bolt. Check it and make sure someone has not hooked it up to the starter hot terminal.
Old Sep 10, 2013 | 09:47 PM
85camarocrazee
Thx Tim. I have pulled that one apart a few times and reconnected it after cleaning...
Wombvette, just the type of techy info I was hoping to get. Ill check it and reposrt back in the next couple of days....
To Intermittent no start
