Caliper pistons popped out while installing...
Old Jul 2, 2002 | 01:26 AM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Caliper pistons popped out while installing...
Hey everyone, it's been awhile since I've posted. I'm knee deep in my front end and engine rebuild. And I have a question.
I was trying to fit the front right caliper over the rotor, and I went to push the brake pads in to provide clearance for the rotors. I had a lot of difficulty, one piston would go in, the other would push out. Then, two pistons popped right out of their bores, and brake fluid went everywhere.
What do I do? Can they simply be reinstalled? Is this a sign that new calipers are in order? Before this happened, my brakes were nice and firm, no leaks.
What do you all think?
Thanks in advance.
:cheers:
Old Jul 2, 2002 | 01:55 AM
theandies's Avatar
theandies
Default Re: Caliper pistons popped out while installing... (joeveto)
Been there...done that. I only had one come out on me and not very far but fluid did leak out a little. I got it back in without much effort, bled the caliper and my brakes are fine. I even use DOT 5 fluid and have manual brakes. My pedal is very firm. I am doing a front end rebuild right now and cut some pieces of wood to fit between the brake shoes to hold them it is working so far and I should be able to use the wood as a spacer when I go to reinstall the caliper on the rotor.
John
Old Jul 2, 2002 | 03:07 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
I think that if you would have opened the bleeder. The pistons would have slid right back in...
Old Jul 2, 2002 | 03:28 AM
joeveto's Avatar
joeveto
Cruise-In V Veteran
DOH! Imagine me slapping myself, right now.
You are right. Open the bleeder, pads move in.
Thanks for pointing out the obvious. I'm at that point, right now, where I need all the help I can get. I want so badly for this car to be done, that I'm throwing money at simple things. You better believe I had my finger on the trigger of a new caliper purchase.
Thanks guys! :yesnod:
Old Jul 2, 2002 | 03:34 AM
LATNC3's Avatar
LATNC3
leave the springs out....i did and had no problems!!!
Rod :cool:
Old Jul 2, 2002 | 04:02 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Caliper pistons popped out while installing... (Desertdawg)
Make sure not to let it squirt brake fluid all over your paint.
Brake fluid will eat paint faster than you can say "Ah schlitz!!"
Old Jul 2, 2002 | 09:29 AM
Stewart's74's Avatar
Stewart's74
I was about ready to send out a search party for ya. Sounds as though things are progressing well on your projects.
As far as the pistons go, you should be able to get them in with a little effort, just be sure not to bugger up the seals.
I'll be ready to drop my engine in this week, wanna help?
Let me re-phrase that, I need help.
Stew
Old Jul 2, 2002 | 09:37 AM
Fevre's Avatar
Fevre
I bought a caliper piston retainer that slides over the caliper and holds the pistons in place then you install the caliper then it slides right off. Think I got if from ZIP or Mid American. Made it alot easier to work on them. It is just a formed piece of sheet metal but was worth the $10 or so I paid.
[Modified by Fevre, 7:37 AM 7/2/2002]
Old Jul 2, 2002 | 11:20 AM
NHvette's Avatar
NHvette
Default Re: Caliper pistons popped out while installing... (Fevre)
If memory serves me ...
The two important things to remember here are :
Keep everything CLEAN. If the piston and seal are dirty - take them
all the way out and clean well - and light compressed air. Carefully
wipe the bore clean - if needed
When working the piston back into the bore, the seal will need help.
Use a 10mil feeler guage to help (gently) shoe-horn the seal edge
into the bore. Be careful not to scratch the bore.
You may even consider (since it is basically apart) a new seal kit. If the bores aren't scored badly, the new seals will give your calipers a new
lease on life.
Why you listening to me ? :smash: My vette's in a gazillion pieces !! :seeya
Old Jul 2, 2002 | 11:30 AM
theandies's Avatar
theandies
Default Re: Caliper pistons popped out while installing... (BSeery)
Not mine......................DOT 5 :yesnod: :yesnod: :yesnod: :yesnod:
John
Old Jul 2, 2002 | 11:56 AM
The Dude's Avatar
The Dude
I usually open the bleeder(s) and then use a 4" spackling knife as a shim to hold the pistons out of the way and help ease the pads in.
Necessity, as they say, is the mother of invention.
Old Jul 2, 2002 | 05:17 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: Caliper pistons popped out while installing... (LATNC3 (Rod R))
take a dull bladed screw driver and work the piston seals back into the bore.I just rebuilt my caliper and thats how i did it.have had no leaks since.you can get caliper rebuild kit for around 11 bucks i think i paid for kit.
Old Jul 3, 2002 | 01:28 AM
joeveto's Avatar
joeveto
Cruise-In V Veteran
Thanks for all the replies.
Stew! You have mail. I can help you, if you still need it. I'm busy Wednesday, but I'm pretty free after that.
To Caliper pistons popped out while installing...
