31 year old tires pass a safety inspection? That kind of discredits the inspection if you ask me. I wouldn't leave my driveway on tires that old and hard. That could be the difference in ride your looking for.
<<31 year old tires pass a safety inspection? That kind of discredits the inspection if you ask me>>
I totally agree!!!!
Totally agree, 5 years from the born date on the tire. Check the DOT code.
Anything older than 5 years would not pass a DOT inspection. Al
Apparently they check the tires for checks and cracks and measure the tread thickness. And since these tires don't have any dates of manufacturer then that's it.
I will replace the tires but it takes a special order and will get that done this winter.
Right now I need to make a decision about the suspension to soften the ride and move forward. Then I can get the Out of Province Inspection and plates.
Thx John
I would bet that new tires will make a very noticeable difference in the way it rides. Old tires are usually hardened and ride like bricks. I would do that before chasing down more expensive suspension solutions since you need new tires anyway.
Honestly, I know the tires need replacing but don't think they are the cause of the the hard ride issue.
A friend has a Berlina with 3 year old tires. I rode in his car and it's the same hard ride by design. A little softer because he took off his front sway bar. So I'm researching the softer suspension for both cars. Surprisingly his car didn't roll in the turns with out the front sway bar.
I believe a test ride with the right shocks would be a good next step. Then decide to play with replacement coil springs or buy the adjustable fiberglass mono spring.
I phoned Corvette America and inquired about the ride of the fiberglass mono spring front suspension upgrade. The rep I talked with said he is going to make some phone calls.
When he got back to me he said the fiberglass mono spring front suspension is not the right one for my car. I believe he said there is 2" less suspension travel with the mono spring. And he didn't have anything else to recommend.
So I'll be trying softer shock absorbers,... and if that doesn't help enough then will be looking for another spring.
If it really has a 7/8" rear sway bar, it's probably the aftermarket style that is the wrong design for our cars. get rid of the rear sway bar completely or go with a stock 7/16" rear bar.
The rear 7/8" swaybar is unnecessary and DOES affect ride quality. I would remove it first and see if you like how the car handles/rides. If you want a rear sway bar, then go with a stock 7/16" or 9/16" swaybar with the factory linkage. Don't use a rear sway bar that uses the bushing's on bolt style connection (ie. same as front).
Also, if you have a fiberglass spring in the rear and want a soft ride, I strongly recommend getting the KYB GR2 shocks from VBP specifically valved for fiberglass springs.
I understand your concern about the front end, but if you look at where you sit, you are almost on top of the rear tires. Tuning the rear suspension will have a larger effect on ride than the front.
If you do remove the rearsway bar or go to a stock one, then you could also decrease the front sway size. Probably down to a 7/8 or 1" one would be a good place to start.
Good Luck
Thx Gwank,
Thx Jason. Your giving some fine advice.
The VBP specifically valved for fiberglass springs and a soft ride?
I'll be checking them out. That's the related info I'm looking for.
It has Carrera shocks. I removed them. They have 3 settings adjustments but I can't change them and don't know if 1 is hard and 3 is soft or the other way around. Doesn't matter, I will replace them.
Back to the weight distribution. The total weight of the Berlina is 3357 lbs. The front end weighs 1505 lbs and is 250 lbs lighter than stock. The rear got heavier by 80 lbs and weighs 1812 (lbs).
The weight ratio changed to 45% front and 55% rear.
The front suspension got rock hard with the weight reduction and almost like no suspension at all. The rear (suspension) got heavier by 80 lbs and rides pretty good.
I do have the rear sway bar that mounts to the frame in bushing on bolt and similar to the front. I just paid to have it powder coated?
The ancient tire issue may be have more impact than you think. And hard to judge your changes on stone tires. Maybe go to your local tire place and see if they have some modern used tires you can put on cheap. Offer to let them find your white walls for later and maybe they cut a very nice deal on the temp tires you return later to them.
I agree, the mechanic passes the old tires in the inspection and then says the rear wheel bearings are bad when he would only check them for up and down play. I'm no mechanic and showed him there is no play other than vertical. He couldn't understand the rear suspension.
