Amp Meter
Old Sep 9, 2013 | 08:58 AM
71Blue's Avatar
71Blue
Default Amp Meter
My 72 LS5 starts and runs fine. The problem is that when It starts the amp gauge goes all the way 40+ and then after a few seconds it starts to return to normal. THis happened with my 5 year old battery as well as a new 790 amp Die Hard. I'm pretty sure this isn't normal even though everything seems to be working. What could be wrong? Thanks,BK
Old Sep 9, 2013 | 09:43 AM
wombvette's Avatar
wombvette
As long as it drops back to just a minor reading, it is perfectly normal.
Old Sep 9, 2013 | 09:48 AM
71Blue's Avatar
71Blue
Thanks for the quick reply. Just what I wanted to hear.
Old Sep 9, 2013 | 11:56 AM
7T1vette's Avatar
7T1vette
The meter is acting normally. But, if you get this +40 amp behavior with each quick start-up (you don't have to crank it much), then you likely have a problem with your battery. Normal starts don't take that much 'juice'...the ammeter may go over to +20 and drop back in 2-3 minutes. When it needs higher amperage to recharge and it takes longer to get back to "0", the battery is getting weak.
Old Sep 9, 2013 | 02:48 PM
71Blue's Avatar
71Blue
Thanks 7T1vette, that is what I thought. That was the reason I got a new battery, but still the same result. I thought the new battery might not be fully charged,but same result after 30mile drive. Going to drive 100 miles tomorrow-see what happens.BK
Old Sep 9, 2013 | 03:49 PM
wombvette's Avatar
wombvette
So just how much does it charge after a couple of minutes?
Old Sep 9, 2013 | 03:52 PM
MelWff's Avatar
MelWff
As others stated, normal, but check the contacts in the white plastic plug, side of alternator, with the two wires for any signs of corrosion.
Old Sep 9, 2013 | 04:26 PM
7T1vette's Avatar
7T1vette
I agree. Check the contacts and terminal connections for alternator and battery wiring. It could be that the alternator is sensing a high resistance somewhere and interpreting that as needing to send max voltage to the battery.
Old Sep 9, 2013 | 05:35 PM
71Blue's Avatar
71Blue
OK cleaned alt terminals,didn't look bad. Started car(first time in 3 days) Gage went to 40, after a couple seconds went down to 20,after 2min down to just right of 0. Started again after 10min run, did the same. Started 3 more times,did the same.
Old Sep 9, 2013 | 06:23 PM
BlackC3vette's Avatar
BlackC3vette
Depending on the accuracy of the gauge, it may not be totally zero. To check the system, I put an amprobe on the negative battery cable and check the amperage after it's started and then after a few minutes. It should be high right after initial startup with the amperage falling down to about 6 to 10 amps (with a charged battery). Check the battery voltage before you start the car, it should be 12.6 volts.
Just for an FYI, if the amperage in the system is still high, the battery could be at fault causing the alternator to constantly produce current and burn up the alternator. People who go thru several alternators in a short period could possibly have a battery problem.
Old Sep 9, 2013 | 07:11 PM
wombvette's Avatar
wombvette
Sounds like a little bit sensitive gauge, but normal operation.
Old Sep 9, 2013 | 09:01 PM
71Blue's Avatar
71Blue
wombvette I think you are right, at least I hope so. In any case I'm not going to worry about it. Thanks - will update
To Amp Meter
