69 brake questions
Old Sep 9, 2013 | 10:24 PM
69for2's Avatar
69for2
Navigator
Default 69 brake questions
I finally got around to replacing my calipers. I have removed them and tried to remove the front rotors to have them turned. They appear to be riveted to the hub. Apparently the whole hub has to removed from the spindle to drill the rivets? Are the rivets needed when putting them back on? Am I missing something?
I am also trying to replace the parking brake shoes and hardware. It appears the lever the cable hooks in does not come out without pulling the hub. I thought it might come out by loosening the backing plate but the more I look at it I am thinking not. Any input is appreciated.
Old Sep 9, 2013 | 10:49 PM
TimAT's Avatar
TimAT
On the front, remove the hub and rotor as a single unit. It's time to repack the wheel bearings anyway. Don't drill the rivets out of the front.
Rear is a little different. Lots of threads on CF about the rears.
Old Sep 9, 2013 | 11:45 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Do your rotors need to be turned, I have original rotors on my original owner 1968 (97,000 miles) and my original owner 1970 (163,000) miles and rotors have never needed turning. Look good and feel good. I have repacked the wheel bearings several times.
Old Sep 10, 2013 | 10:32 AM
my 76 ray's Avatar
my 76 ray
I agree with both of the above posts. Your rotors may not need turned but if they do, just take the entire hub/rotor assembly to the shop.
Old Sep 10, 2013 | 10:43 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
The rivets are not needed, in as much as the wheel holds the rotor on.
But the rivets do help keep the runout of the rotor in check. and prevent the rotor from flopping around while you try to bleed the brakes.
Not a big deal of youre calipers are in excellent condition, but will let air into the fluid of your lip seals are not perfect.
If you replace the rotors, replace a couple rivits with screws and life will be easier.
Vette valipers can be a bit.. to bleed
Old Sep 17, 2013 | 11:17 PM
69for2's Avatar
69for2
Navigator
At this point I know more about the brakes on a 69 then I ever thought I would. I have the parking brake system replaced and working. I have a couple questions for you gents. I thought I would leave my front rotors in place as they are riveted to the original spindles at 68K original miles. The rears have been drilled and were beyond turning so I replaced them. After putting the new rears on I have run out of .003 passenger side and .004 on drivers. I have read that .002 was the factory spec but have also read that .005 is OK with O ring calipers which I just installed. Should I shim for less run out?
This got me wondering what my original riveted front were like. I put the indicator on them and found .009 passenger side and .008 drivers. They are currently 1.230 thick. Looks like I will be drilling the fronts off and turning or replacing. Sound like the right direction?
Old Sep 18, 2013 | 10:01 AM
7T1vette's Avatar
7T1vette
Re-index the front rotors to different studs and then check runout again. If the runout stays the same, just shim where needed to get it where you want. If it changes, keep indexing the rotor till you find the position having the least runout. No matter what route you go, there is no need to drill out the rivets.
Old Sep 18, 2013 | 11:59 AM
noonie's Avatar
noonie
Do not drill out the front rivets and separate the rotor from the hub.
Riveted together, the fronts assembly is exactly the same as a gazillion other GM " one piece" assemblies of that era.
A standard brake lathe that uses the bearing races to mount the rotor/hub assembly is all you need to true the fronts.
The ONLY reason to separate them is if you must replace the front rotors if they are to thin to turn and if that is the case, then bolt the new rotor to the hub and use the same standard lathe.
Depending on mileage, it may be a good time to install new front bearings and races BEFORE having them turned.
Old Sep 18, 2013 | 05:23 PM
69for2's Avatar
69for2
Navigator
How would you re-index the rotor on the studs if it is riveted in place?
To 69 brake questions
