Transmission shifter seal replacement
Old Sep 15, 2013 | 07:46 AM
1974ta's Avatar
1974ta
Default Transmission shifter seal replacement
Can I pop out the seal for the reverse lever without disassembling the trans. It is an M20 1970 vintage.
Thanks,
Bill
Old Sep 15, 2013 | 06:10 PM
DUB's Avatar
DUB
I have done it in the past...very carefully.
VERY SHARP strong pick and patience. Similar to the process of removing a harmonic balancer seal....if you have done that. Once it is out...I use a collar( socket) to aid in getting it installed and seated.
DUB
Old Sep 15, 2013 | 07:48 PM
1974ta's Avatar
1974ta
Default seal
Thanks DUB.
I may give it a shot.
Bill
To Transmission shifter seal replacement
