Internal exhaust ceramic coating test
Old Sep 18, 2013 | 09:02 PM
rafalc's Avatar
rafalc
Default Internal exhaust ceramic coating test
So during my little project I decided to use the Eastwood internal exhaust coating on the inside of the headers and all of the pipes.
Post # 51 --> http://forums.corvetteforum.com/c3-g...project-3.html
I decided to do a little test. I left one pipe section (one that runs under the spring) uncoated, ran the motor for 10-15min and used a heat gun to see the temp difference.
Picture 1, coated. Picture 2 uncoated.
While the motor was running, the uncoated side gave a reading of anywhere from 5 to 12 F hotter, depending where I pointed the gun. Not sure if the differences were due to the different locations on the pipe or the gun being a cheap HF gun.
The interesting thing was that after shutting the motor off, things started cooling off and the UNCOATED side was cooling quicker than the coated side. Constantly giving a reading of 5 - 10 F cooler. I was a little surprised by these results but then did some research and found out that ceramic heats up slower but also cools down slower therefore not cracking as easy from the heat cycles. Whether true or not...whether this coating is working or not.... who the hell knows, I can just go by what the cheap gun showed me.
Old Sep 19, 2013 | 08:17 AM
jotto's Avatar
jotto
Did you only take temps at the rear or did you also get them at the headers?
Old Sep 19, 2013 | 08:29 AM
rafalc's Avatar
rafalc
Only took them at the rear as only that one right section was left uncoated. Everything else was already coated. I wanted to compare similar sections which were identical distance from the motor to have a like-to-like comparison especially with the X-pipe helping to distribute the heat more evenly towards the rear
Old Sep 19, 2013 | 08:47 AM
Jig A Low's Avatar
Jig A Low
the thing with the ceramic is called "thermal mass", granted it's not a lot of mass but it's still mass, the same concept is used in heating homes with sunlight, lots of thermal mass (i.e. bricks, stone, tile), the sun heats is during the day then the material releases it slowly thoughout the night. different process/same concept.
Old Sep 19, 2013 | 09:05 PM
scottyp99's Avatar
scottyp99
LOL! I looked at the first pic and said "1235 degrees F? Damn, that's hot!!" Obviously, it must be 123.5 degrees. Those little temp guns seem pretty cool, I'm thinking about getting one, how do you like it?
Scott
Old Sep 19, 2013 | 10:38 PM
rafalc's Avatar
rafalc
Scott
I only got the gun for this one purpose..... I'll probably end up returning it as I cant think of any other use for it
Old Sep 19, 2013 | 11:33 PM
scottyp99's Avatar
scottyp99
I wonder how that internal coating would work as an external coating on a raw steel set of headers.....
Scott
Old Sep 20, 2013 | 12:26 AM
Coatthis's Avatar
Coatthis
1st Gear
Unfortunately, there are likely many reasons why this test isn't going to yield useful results.
1) First and foremost there is little to no "ceramic" in an over the counter $10.00 - $20.00 thermal coating or header paint. At best it’s a silicone based coating that may hold up to some heat. Or perhaps a few specs of ceramic to prevent false advertising.
2) How did you clean out and prep the pipes for coating. Commercially they would be burned at about 700F-900F for 4-5 hours to burn off any organics (mandrel grease / oil). Then they would be internally blasted / profiled so that the coating has something to bite in to. If the ID of the pipe is still contaminated the coating will separate as if you were trying to paint an oily panel.
3) Once you insure that you actually have coating on the ID of the pipe you need to measure a consistent area of straight pipe as the bends will thinned out in different areas.
4) A cheap IR temp gun will NOT yield accurate temps from a reflective substrate. More expensive guns can be calibrated to do this. As a general rule you will see variances of 50F – 150F+ below your actual temps. Its best to put paint on your test site to eliminate the reflection.
5) As for the function of actual exhaust thermal barriers / ceramics, they will reduce the rate at which temps permeate the coating / substrate. Once they are heat soaked they will actually dissipate heat quicker than the raw substrate. For example, if you have ceramic coated headers you will notice that you can actually put your hands on the coated headers very soon after shutting the engine off. In the case of your pipes being hotter after they are were off this can be the result of not being coated and or denser substrates like SS as opposed to mild steel.
Old Sep 20, 2013 | 02:07 AM
iokepakai's Avatar
iokepakai
Temp gun can also be used as a tuning-troubleshooting tool.Found a bad spark plug that was causing a miss at times.Started the motor ,while it was warming up checked each cylinder's temp.Found one that was cooler than the others,replaced that plug no more miss!! Was a new plug !!
Old Sep 20, 2013 | 08:16 AM
rafalc's Avatar
rafalc
Good point. I was actually going to do the water trick for that. Let the motor heat up then squirt some water on each header primary and see how fast it evaporates. A gun obviously will give you an actual reading.
Old Sep 20, 2013 | 11:38 AM
Shark Racer's Avatar
Shark Racer
I use my temp gun to check the temperature of the oil bath I use for making fried chicken...
Old Sep 20, 2013 | 05:24 PM
scottyp99's Avatar
scottyp99
I think the main thing about a cheap IR temp gun (Harbor Freight has 'em for about 25 bucks) is that, even though it may not give an accurate temperature, it should still give you a fairly accurate way to judge temp differences. How often do you really care about the exact temp, as opposed to making a change, and noting the temp difference it makes?
Scott
Old Sep 20, 2013 | 05:43 PM
toddalin's Avatar
toddalin
This is exactly what I would expect to happen.
The coating acts as a barrier. When you are making heat in the pipe, the barrier keeps some of this heat from getting through before making its way out the tail pipe. But the metal pipe coated in ceramic still gets damn hot.
So when it starts to cool down you've removed the heat source from inside the pipe but you still have hot metal. Now the coating is acting as a barrier to keep the heat from escaping the metal into the air, at least on the coated side.
Old Sep 20, 2013 | 09:29 PM
rafalc's Avatar
rafalc
Thats exactly what I learned about ceramic when I looked it up after seeing these results. So I guess the verdict is that the coating does work. Is it worth the 10-15 degree difference? Would I have seen more of a difference if I ran the motor longer? Maybe.
All I wanted is to keep the cabin cooler and the fiberglass spring safe and with the coating starting with the headers all the way back, lizard skin, new transmission tunnel insulation, and heat shield right around the spring area I think I should be just fine.
Old Sep 20, 2013 | 10:13 PM
dmaxx3500's Avatar
dmaxx3500
i use mine to ck tires and hubs on truck and trailers all the time
Old Sep 20, 2013 | 10:16 PM
dmaxx3500's Avatar
dmaxx3500
Scott
i had a powder coater coat every one of the exhausts i used to do inside and out [headers ,pipes ,mufflers ,tailpipes]they looked great years later
Old Sep 20, 2013 | 10:36 PM
toddalin's Avatar
toddalin
I also did several coats on the bottom (inside and out) of my air cleaner.
To Internal exhaust ceramic coating test
Old Sep 30, 2013 | 11:28 PM
rafalc's Avatar
rafalc
I took some more measurements today. After a long drive I parked and kept the motor running. Here is what I got (averaged the readings as I could not get one steady reading)
At the header primaries:
Cylinder #
1-240 F
2-280 F
3-310 F
4-240 F
5-250 F
6-240 F
7-250 F
8-310 F
At the exhaust pipe right under the rear spring: 140 F
Bottom of fiberglass spring right over the exhaust pipe: 120 F
So the internal coating along with the heat shield, keeps the spring around 20 F cooler that the pipe right under.
Old Sep 30, 2013 | 11:57 PM
cv67's Avatar
cv67
St. Jude Donor '05
W/Scotty they will give you a general idea
They will only read surface temp not whats inside
Wonder if plumbing the coolant front to rear on the intake would change cyl temps any always bugged me how some cyls run so much warmer than others.
Id think if someones tuning from general A/F ratio #s the hotter cyls would be running leaner too
or at least be more prone to detonation.
Old Jul 22, 2019 | 10:06 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Now you are talking the language of race engine builders, head porters, intake manifold flow distribution and NASCAR. Old school SBC & BBC need a lot of correcting. Newer cylinder head designs are way better / more even and so are the LS motors. It's one of the reasons CNC ported heads way outperform as cast ones.
