The Infamous Differential Code Question
Old Sep 19, 2013 | 08:56 AM
coolhandluke74''s Avatar
coolhandluke74'
5th Gear
Default The Infamous Differential Code Question
why cant i find my differentials codes on any GM site, or eaton or any other for that matter. there is a 'GM' stamped right into the casting (actually protruding from casting). and during most searches i am referred to a gasket face identification chart, what the #$@%, I've got the numbers right here, lets use em! as you may have seen yourself none of these gasket face identifiers include an 8 bolt IRS style diff. the lowest bolt count i find is 10, makes me want to drink! furthermore the guy who stamped my diff. on the bottom was obviously hung-over and let the stamp bounce on the first letter which is an 'A' so there are 2 'A's overlapping eachother... im not sure if there is supposed to be 2 or 1???!!! whew! i feel better already, so there is a 'GM' with a '13' above it, also a 'G64' and 'C2' as well as the hand stamped 'AWW198E2' and as i said the 'A's are on one another so it may be 'AAWW198E2' but i doubt it. P.S. i know it is a 3.08, thanks to any helpers!
Old Sep 19, 2013 | 09:13 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
annnnnd another thing......unless you're the original owner---there may be some different gears installed by someone else along the way.
Old Sep 19, 2013 | 09:26 AM
jbrown8238's Avatar
jbrown8238
NE Events Coordinator
I believe, from looking at several sources, that your code is broken down as follows:
AW - 3.08:1
W - Warren Michigan Plant
198 - Julian date of manufacture
E - Eaton posi-traction
2 - Shift that assembled the unit
Assuming it's a 74 from your screen name, I believe the differential cover is 8 bolt, ecklers has the gaskets http://www.ecklerscorvette.com/1974-...sket-rear.html
Hope that helps and/or is what your looking for.
Old Sep 19, 2013 | 09:04 PM
coolhandluke74'
5th Gear
Thanks, where did you get that info, i found no codes that started with an 'A' . I was initially looking for information about torque ratings and overall reputation of the rear end i.e. bearing problems, seals leaking,... just wanted to know if its worth a dang before i spend any money on it! im looking to get a 3.73 gear set and will be replacing the bearings and seals when i do that. there is a pletera of info on the 10 and 12 bolt patterns but it just frustrated me to find virtually nothing on my 8 bolt IR. and f.y.i. i would be buying the parts from Ecklers. unless anyone has a Cheper place to get the parts. You could peice together an entire Vette from Ecklers, but boy are they pricy!
Old Sep 19, 2013 | 09:18 PM
Hammerhead Fred's Avatar
Hammerhead Fred
Better question is where are you looking as all but one of the codes from 71-75 start with "A". Found in almost all Corvette spec guides and on many web sites.
Old Sep 19, 2013 | 10:27 PM
jbrown8238's Avatar
jbrown8238
http://corvette-world.com/corvette_1...tification.php
Old Sep 20, 2013 | 11:40 AM
tracdogg2's Avatar
tracdogg2
10 or 12 bolt only denotes the number of bolts on the ring gear, has nothing to do with the rear cover.
Mike
Old Sep 23, 2013 | 03:47 PM
Ecklers Vette Tech's Avatar
Ecklers Vette Tech
AW - 3.08:1
This info is correct! If you would like to order any new parts, shoot me a pm and I will see what we can do with the price and shipping!
Thank you very much,
Eckler's Family of Automotive Parts.
To The Infamous Differential Code Question
