Front wheel clearance question
Old Sep 20, 2013 | 11:26 AM
Madmiel's Avatar
Madmiel
Cruising
Default Front wheel clearance question
When I put my Vette on the ramp with the wheels of the ground I can tilt the left front wheel up and down (5⁄32in
). The parts that are moving are the wheel and the brake disc. Caliper and arms aren't moving.
Does this mean my bearings are damaged / gone?
Old Sep 20, 2013 | 11:31 AM
tracdogg2's Avatar
tracdogg2
Possibly.
Definitely need to be looked at.
Mike
Old Sep 20, 2013 | 01:04 PM
Madmiel's Avatar
Madmiel
Cruising
What's the best approach to check if the bearings are causing the problem?
Old Sep 24, 2013 | 12:18 PM
Madmiel's Avatar
Madmiel
Cruising
I took of the wheel hub and removed the seal, bearings and races. I ordered new ones and installed the outer race. To my surprise I could almost push in the race with my fingers.... It's in place now but you can turn it and it has some clearance. I don't think this is a good thing.... should I be looking for a new wheel hub?
To Front wheel clearance question
