Cowl Induction?
Old Sep 25, 2013 | 10:41 PM
  #41
cv67's Avatar
cv67
St. Jude Donor '05
Mike where did you get that black foam at?
Old Sep 25, 2013 | 10:50 PM
  #42
Mike Ward's Avatar
Mike Ward
Originally Posted by TheSkunkWorks
Without pressure differentials, there is no flow. Higher areas of pressures always seek to flow into lower pressure areas, so flow is most definitely evidence of "pressure". Basic thermodynamics, period. (No large print required.)
You meant 'aerodynamics', but I get your point and agree.
When in motion, a properly isolated cowl air charge will tend to be above ambient pressure, and it doesn't take a supercharged size pressure differential to measurably improve induction efficiency (let alone the effects of significantly lower temp air).
Again I agree- except and as stated further above, the stock configuration of a C3 is not conducive to developing a properly isolated cowl charge.
The point of my experiments in the linked post and later backed up by noonie's, was that a stock '73-'75 with open snorkels does not create enough pressure in the cowl to cause flow into the air cleaner housing. This is witnessed by no decrease in temperature inside the air filter housing at speeds up to 100 mph. Had there been significant flow, the air temps would have decreased markedly as the flappers opens with WOT. No such drop occured.
Noonie's test indicates that with the same two snorkels blocked off and the flapper removed, the housing air temperature drops to almost ambient. This decrease in temperature is simply because the source of air to supply the engine is exclusively from the cowl via the underhood ducting. The flow is created by intake manifold vacuum, not because of cowl pressure.
Old Sep 26, 2013 | 07:28 AM
  #43
MIKE80's Avatar
MIKE80
This is what I used. I slit the bottom of the foam to go around the edge of the air cleaner pan that I made and glued the ends of the foam together.
Here's a link to the foam.
http://www.jegs.com/i/Moroso/710/970...oductId=745281
Here's a link to a thread I did on the CAI.
http://forums.corvetteforum.com/c3-t...80-hood-4.html
Old Sep 26, 2013 | 01:45 PM
  #44
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
addballer696,
I too am interested in your setup. If you get a chance, can you show a pic from the engine compartment to the top of the firewall without the induction tubes? I'd like to see exactly where you cut the holes. Hence, my curiosity on how you did it with 4" tubes. Nice job btw. It's exactly what I was thinking but using 3" tubes.
Old Sep 26, 2013 | 05:31 PM
  #45
addballer696's Avatar
addballer696
Originally Posted by resdoggie
addballer696,
resdoggie, heres the best I can do. The car is with my parents cuz im in med school right now, but basically its gonna be a really tight fit. The one closest in the picture is gonna be a little closer to the center than the other tube. If you decide to use the spectre connectors its gonna be impossible. The tubing isn't straight and you have to use some sort of connection that you can have some give with. What im trying to say is the metal isn't flush. But everything is very solid and there is no way that its coming apart. I also chopped off about an inch of the "verlocity stacks" so they sit flush with the bottom of the cowl area, but are still high enough that no water will get in. And yeah on the top I cut a slit so they slide right in that gap and that holds it in place very nicely, no glue or anything like that needed. Also If you buy the K&N filters (Mine were 4X6x2) you will need to grind off some of the rubber ring on the 4" circumference so that they will fit snug in the tubes.
Old Sep 26, 2013 | 05:48 PM
  #46
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Thanks, Doc! Did you ever consider using 3" tubing?
Old Sep 26, 2013 | 06:38 PM
  #47
addballer696
na, go big go home baby
Old Sep 26, 2013 | 08:49 PM
  #48
cv67's Avatar
cv67
St. Jude Donor '05
Mike
Thanks. Link was to youtube vid?
What was the avg temp in the air cleaner assy vs the ambient/underhood curious .
Old Dec 1, 2014 | 08:06 AM
  #49
doorgunner's Avatar
doorgunner
2026 Loser of the Year
To The Top..........................
just because it has so much useful info!
Old Dec 1, 2014 | 02:09 PM
  #50
Kid Vette's Avatar
Kid Vette
Originally Posted by Mike Ward
And of course I remember that post well.
Your tests certainly showed a temp decrease after modifying the air cleaner assembly (no doubt about that) but is indefinite about a pressure increase. Please compare that to my tests of the stock assembly which showed no pressure increase or temperature drop.
Again- the conclusion is that there's no PRESSURE INCREASE in a C3 cowl area below 100 mph.
Old Dec 1, 2014 | 02:40 PM
  #51
pauldana's Avatar
pauldana
Originally Posted by Kid Vette
:rof l::r ofl: :rof l:
Old Dec 1, 2014 | 02:42 PM
  #52
Mike Ward's Avatar
Mike Ward
Originally Posted by doorgunner
to the top..........................
Just because i want to stir the sh*t again.
FTFY
Old Dec 1, 2014 | 02:43 PM
  #53
pauldana's Avatar
pauldana
Mike
on my CAI unit, I MEASURED a greater than 45* temp difference between the bowl area and just outside what would be an exposed filter.
Also, I had a +.2psi boost in pressure in the bowl as compared to the area just outside what would be an exposed filter.
Old Dec 1, 2014 | 04:33 PM
  #54
Mike Ward's Avatar
Mike Ward
Once again, it's like I can predict the future. The peanut gallery is out in full force
Old Dec 1, 2014 | 06:10 PM
  #55
Petes73's Avatar
Petes73
If that's a 'cowl induction' system, what are those two large tubes leading forward over the top of the radiator?
Why can't I see any ducting that actually goes rearward to the cowl?
Unless Chevy put the distributor on the front I would say the ducts do go to the cowl
Old Dec 1, 2014 | 06:59 PM
  #56
Mike Ward's Avatar
Mike Ward
Click on the link in the post and tell me what you see.
Old Dec 2, 2014 | 01:17 AM
  #57
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Unless isolated to the induction system, opening up the cowl to the engine compartment doesn't necessarily provide the functionality of genuine cowl induction. While a properly sealed CAI can increase induction pressure by a measurable amount above the throttle body (carb or injection), it's the added density of the cooler air being ingested that more significantly affects engine output. However, although there is most definitely a pressure build up at the base of the windshield at work here, without isolation the differential from the cowl area relative to engine compartment pressures may not always be sufficient to push airflow inward. Thus, proper isolation of the CAI system is somewhat necessary to assure that cooler, denser air charge actually makes the trip from the cowl all the way to the throttle body rather than becoming diluted with heated air.
We can dive more deeply into the whys and wherefores if need be, but IMHO that is probably best left to more comprehensive discussions on C3 aerodynamics as a whole. Suffice it to say that IMCO creating new openings into/from the engine compartment shouldn't be taken lightly or without doing a bit more research than simply scanning thru a couple of threads on the interweb such as this one.
Anyway, hope that helps more than causes any further confusion.
Kid Vette, that reply you posted "by" Zora is absolutely priceless.
To Cowl Induction?
Old Dec 2, 2014 | 08:56 AM
  #58
doorgunner's Avatar
doorgunner
Just because it has so much useful info!
Originally posted by Mike Ward: ftfy
Gee....thanks Mike! Now you've gone and given me a flashback! I'll have you know that it's been 44......yep 44 years since I've stirred any $**t! Seeings how the Generals in Nam decided we needed to pour in jet fuel with the feces/light it with a match/stir it until it was ashes (because the ground was too damp in the monsoon season for the stuff to dry out and be assimilated back into the soil) (FYI)......
So.....you could say that I definitely know my $**t.....and when necessary....How to stir it!
Now that that is cleared up.....had I known that fellow members would have used this thread to rape you so violently, I would not have re-posted it.
I don't understand their outright hatred for you.....you've always been such a nice guy to everyone!
I hope Santa brings every one of them a big bag full of f*****g coal dust......or a picture of Nancy Pelosi.
Now....back to the thread.
Old Dec 2, 2014 | 10:05 AM
  #59
commander_47's Avatar
commander_47
:roc k:
Old Dec 2, 2014 | 10:18 AM
  #60
Mike Ward's Avatar
Mike Ward
I do. There's few guys here that just hate when I burst their fantasy balloons. Makes them look silly in front of their fan club.
After years of boy-racer bench racing over the '73-'75 GM cowl induction system, I went out and tested it on my own car and proved beyond any shadow of a doubt that it doesn't work and why.
The cartoon of Duntov is hilarious, even more so when you understand the joke behind the joke of why his other hand is in his pocket. He had his fingers crossed because he knew he was telling an outright lie.
Even if NO testing had been done, anybody with any common sense would realize that there's no induction system in the world that will shave a full second off the ET of a 190 HP C3 Corvette.
Haters gotta haters and the believers of miracles will continue to believe.
