What gear do I have??
Old Sep 23, 2013 | 11:47 AM
madam's Avatar
madam
Default What gear do I have??
Hoping someone can tell me what my rear end gear ratio is from this data:
76 stingray 350sbc, 350th, tire size 235/60 15, 2200 rpm @ 60 mph.
Thanks.
Old Sep 23, 2013 | 12:10 PM
MelWff's Avatar
MelWff
mathematically 2:84, but could be because you dont have original size tire so 3:08
Old Sep 23, 2013 | 12:54 PM
Mike Ward's Avatar
Mike Ward
If you're stating actual speedo reading, tire size is irrelevant.
Old Sep 23, 2013 | 02:32 PM
MelWff's Avatar
MelWff
Default Please clarify
Since the car has smaller tires the speedo may be reading 60 but the car is actually going at a slower speed, substituting 55 gives you 3:10 which is closer to the actual 3:08, so how is tire size irrelevant to determining the gear ratio?
Old Sep 23, 2013 | 03:42 PM
Mike Ward's Avatar
Mike Ward
If the OP is going by the speedo reading in an effort to reverse calculate diff ratio, actual vehicle speed is irrelevant. The car could be up on blocks with no wheels on it at all and the reading would be the same.
If someone wants to use the on-line calculators to figure out diff ratio, the stock OEM tire OD/size must be used and NOT the actual tire size. That's why you ended up with an incorrect answer.
To What gear do I have??
