another carb thread
1975 automatic, stock everything except for full exhaust and headers... idles at 1300 hot or cold. Idle is smooth, and turns on easy.
What I tried:
waited for choke open completely, so engine is hot.
- turned the accelerator screw all the way back, lever is not touching it, still too high.
-disconnected hose to the vacuum system ( wiper, headlight) right by the engine and plugged it. No change.
-break hose was very tight and couldn't take it off on either side ( i don't suspect a leak there)
- forced the choke closed, died instantly. Is that a sign of no leak?
Should I move on to checking the timing? If so, does any mechanic know how to do it or should I tell him how much advance I want?
also, on the picture below, this circle is for the choke, not for the mixture righ? ( it does say lean / rich on it)
* When did this problem start?
* Was it like this when you bought the car?
* Was anything changed prior to the problem starting? upgrades, repairs or adjustments?
If the source of the issue is unknown, first, isolate the carb. Disconnect the throttle cable and plug all the vacuum connections on the carb and the manifold with vacuum caps. See if that changes anything.
Jnd5101, I checked the fast idle screw and... I don't have one, just the hole where it goes. As for the fast idle cam, ( I am assuming its the lever that pushes against the fast idle screw), it's moving ok, doesn't seem to be stuck; moves freely. I will be disconnecting the throttle linkage tomorrow. I'll let you know. As for "put a washer under the carb hold down bolt-and DON'T over tighten it-just snug." I am a bit unclear on what you mean, do i put a washer between the bolt and the carb for every screw that holds the carb to the engine?
Motorhead, I will be cheking the timing tomorrow. I have no engine runoff. My brother has a gun. I will be reading more about it tonight so I am well informed (hopefully) before I attempt anything. I did it on my bother's old beetle a while back.
Also, as some of you mentioned, I did trow some carb cleaner around, no peak in rpm. I am still not fully convinced, since it seems to be quite a common problem to leak around the gasket.
Lastly, I noticed that the accelerator doesnt go back all the way. It only goes back if I manualy pull on the lever, from (1300 goes to 1250). I cleaned, but still not going all the way by itself. Will be cleaning some more tomorrow, but flaps look very clean.
SO tommorrow:
remove throttle cable, see if it goes back.
Cleam carb some more.
Use gun to check timing.
If no avail, I'll be buying a gasket.
I'll let you guys know tomorrow.
Problem started after I fixed the rpm gauge. haha
When I bought the car, 2 weeks ago, the rpm gauge wasnt working. Idle seemed fine by ear, but it clearly wasn't. I wasn't used to corvettes at all, and now that I hear it, it is as high as the rpm gauge says it is. I installed the rpm and did the gauge set, works perfect (pain in the a** to change it)
The car is stock, exept for the exhoust.
As for isolating the carb, I was attepting that today, but I'll buy plugs. (i was isolating one at a time). But can I plug the pcv too? How about the vaccum advance hose ( the one that goes to the distributor? that one too?
Also, the line that feeds the car vaccuum comes of from the top of the engine, not from the carb, so do I need to plug those too?
I realize there are many variables in this but went out and took a couple pictures for you as a reference. My car is a small block with a medium cam and uses manifold vacuum advance. The car idles just over 600 rpms in gear.
You can see several threads on the screw.
I flicked the choke on and took this shot to show the gap that the fast idle cam leaves when it is engaged.
I don't know if that helps or not...
Also, disconnect the throttle cable from the carb linkage and exercise that cable and accelerator mechanism to see if there is any binding in it. You may just need a stronger throttle return spring, if you don't have complete freedom of motion.
Anyways, what I have done is:
-drove the car around to reach good temp,
-removed the throttle cable, lever went as low as possible ( 1200 rpm)
-then I used the gun to check the timing, It gave me 29.
-Removed the vacuum advance and plugged it, Idle lowered a bit (1100 rpm)
-measured with the gun and it gave me exactly 10 degrees.
So, before I open the distributor and put a rubber band on the centrifugal advance to check if its going in too early, I would like to know if 10 degrees is ok, i see people use it at 12.
**I checked for vacuum leak, it has a little tiny bit of a throttle shaft leak. I sprayed with carb cleaner, and right on the lever, it raises a little. When I toggle the shaft, it has an up down play.
are you saying the idle screw is touching the flat and it's still at 1200? look down into the primary butterfly and see if it's totally closed. if it's totally closed, you may have one of those 'commercially rebuilt' carbs that lars has talked about that has been 'reengineered' and has had the idle and primary circuits 'modified'.
With the throttle cable removed from the carb, can't you dial down the idle speed further? If not, you have a significant vacuum leak somewhere. That additional intake air is allowing the idle to increase. You need to locate that leak.
I will leave the timing as it is. Not interested in performance, but would love to have that low idle sound.
Shaft goes as back as it can and seems to close the primary butterflys pretty well.
I will proceed to look for leaks once again.
As for the throttle shaft, is it normal to have a little bit of leak like I have? Maybe that's my problem. (up down play, rests on down)
bem, don't worry about the timing at this point, it sounds like it should be fine where it is, for now. Once you get your idle problem sorted out, we'll get your timing optimized.
Scott
Finally found that the secondary throttle plates were not seating properly in the bores, After re-aligning, the idle dropped down to where it should be.
Some may agrue that this isn't possible, but it sure worked for me.
Good luck!
Duane
