backup light switch
Old Sep 27, 2013 | 06:14 PM
Jumbaliaman's Avatar
Jumbaliaman
Default backup light switch
I recently purchased a 71 vette and the back up lights don't work. when i looked under the car on the transmission i don't see a switch or wires or anything. The previous owner replaced the transmission with a Borg Warner Super T-10. My question is if i buy the switch from corvette central will it work on this transmission? Is the hookup the same?
Old Sep 28, 2013 | 06:37 PM
DUB's Avatar
DUB
You have to specify for that type of transmission...and you have to make sure that there is a very small hole ( just under 1/8" approx) in the linkage plate that is bolted to the reverse stud coming out of the side of the transmission.
One for a Muncie will work but you have to modify mounting and switch it around.
DUB
Old Sep 28, 2013 | 06:38 PM
fanmanbd's Avatar
fanmanbd
You will need to buy the switch bracket and shaft for the T-10.
Old Sep 28, 2013 | 11:55 PM
Jumbaliaman
ok thanks guys
To backup light switch
