Won't Start
Old Sep 28, 2013 | 06:43 PM
Vette79C3's Avatar
Vette79C3
Default Won't Start
I have a '79 C3 Auto L48 with a complete Top-End Rebuild. She ran fine 3 weeks ago, I go out to start her up for a quick cruise and nothing. When I turn the key to start, no clicks, no crank but interior lights go dim. I have proper voltage at battery terminals and same voltage at generator. Starting to think it the Starter but haven't had much time to continue to troubleshoot it. Any direction would be appreciated. Thanks!
Old Sep 28, 2013 | 07:43 PM
Ironcross's Avatar
Ironcross
Check and clean your ground, especially the short one to the frame behind the drivers seat to the battery
Old Sep 28, 2013 | 08:05 PM
wnmech's Avatar
wnmech
Do you have voltage at the starter?
Old Sep 28, 2013 | 08:25 PM
speedreed8's Avatar
speedreed8
try putting it in neutral and start. or move the shifter around.
Old Sep 28, 2013 | 08:54 PM
bluedawg's Avatar
bluedawg
This is the usual suspect. The grounds seem to be more critical in a c3, probably because the the body is made of fiberglass.
Old Oct 1, 2013 | 11:14 AM
Vette79C3's Avatar
Vette79C3
12.5 volts at battery terminal and the same at the alternator but when I put the key in the start position the lights are dim and I have a voltage of 9 volts at battery and alternator. There is no clicking noise and the starter never cranks. All grounds and connections are good. When I attempt to start the engine all interior lights go off. Ideas?
Old Oct 1, 2013 | 11:49 AM
Vette79C3's Avatar
Vette79C3
It's the battery. Thanks for the responses.
To Won't Start
