installing center caps
Old Sep 30, 2013 | 10:49 PM
villare's Avatar
villare
Default installing center caps
Do I need to take the aluminum wheels off to install the plastic center caps on a 1977 corvette or do they get install from the face of the wheels
Old Sep 30, 2013 | 11:16 PM
Mooser's Avatar
Mooser
They go in from the front. The caps have little hooked "fingers" that clip into the groove in the rim center.
You may wish to add a little black rtv to the "fingers", helps them stay put once installed and prevents rattles etc. that seem to plague the replacement caps.
M
Old Oct 1, 2013 | 09:54 AM
villare's Avatar
villare
Thanks M,
The reason that I asked was because I tried about 10 years ago pressing the caps from the front and I did break a couple of the teeth and lost two of the caps soon after i installed them and now I bought some new caps and just wanted to make sure I was doing it right, thanks for the idea of the black rtv
Old Oct 1, 2013 | 12:02 PM
Mooser's Avatar
Mooser
The RTV will also act as a little lubricant when installing them and that helps.
You can also take a file or emery paper and smooth the edge of the rim slightly with the cap goes in to help the fingers start.
M
Old Oct 1, 2013 | 12:16 PM
BKbroiler's Avatar
BKbroiler
The rtv is a good suggestion. Thats what I use on mine.
Old Oct 1, 2013 | 02:17 PM
villare's Avatar
villare
Thank you, I appreciate your sugestions , I will try it this afternoon....Update..Following your suggestion I was able to install the center caps perfectly.
To installing center caps
