Courtesy Lights
Old Sep 28, 2013 | 09:39 PM
shaw1974's Avatar
shaw1974
8th Gear
Just got finished working under the dash of my 76 (heater core and vacuum line replacement) and when I got everything back together, the courtesy lights won't come on when either door is opened. They will come on manually when the headlight switch is rotated. I have a wiring diagram I'm fixing to work through, but any suggestions on where to start looking. Thanks
Update: Found the problem, had knocked one of the white connector wires loose.
