Vehicle Emissions Test Failure
Old Jul 3, 2002 | 01:42 PM
PaceCarTN's Avatar
PaceCarTN
St. Jude Donor '03
Default Vehicle Emissions Test Failure
I just bought a 78 Pace Car (L82) that can’t pass Tennessee Inspection.
The results were:
HC: 593 (Limit 400) Fail.
CO: 4.58 (Limit 4.00) Fail
CO2: 9.63 (Just a reading, not listed as Pass/Fail)
Tampering Inspection Fuel Inlet restrictor: Pass
Tampering Inspection Catalytic Converter: Pass
Tampering Inspection Proper seal in Gas Cap: Pass
I am waiting to hear from the State Mechanic to get an appointment, but was wondering if there is anything I can check that may help with a quick fix. Or if these numbers look unusually high.
:sad:
Old Jul 3, 2002 | 02:48 PM
zwede's Avatar
zwede
Default Re: Vehicle Emissions Test Failure (edm1)
It's running rich. Things to check:
Choke opening all the way?
Clogged air filter.
Main well plugs leaking.
Catalytic converter may be damaged by now if it has been running rich for awhile. If it's the original one you want to replace it anyway as it is very restrictive.
Old Jul 3, 2002 | 08:12 PM
PaceCarTN's Avatar
PaceCarTN
St. Jude Donor '03
Default Re: Vehicle Emissions Test Failure (zwede)
Thanks Markus. I'll check those things.
Old Jul 3, 2002 | 08:29 PM
Doug2500's Avatar
Doug2500
Install a new air filter, new fuel filter, change the oil & filter and a new PCV valve. Take it for a good blast down the freeway to clean everything out.
Old Jul 4, 2002 | 01:25 AM
Stevo81's Avatar
Stevo81
There is a fuel additive that guarantees you will pass that part of the test...sorry I don't know more about it...
Old Jul 4, 2002 | 02:03 AM
MikeC's Avatar
MikeC
Default Re: Vehicle Emissions Test Failure (Stevo)
If need be you can also back off the timing, that will make the car pass emissions but try what Zwede said first.
Old Jul 4, 2002 | 02:24 AM
smonska's Avatar
smonska
Default Re: Vehicle Emissions Test Failure (MikeC)
I feel stupid asking, but what is a fuel inlet restrictor?
Old Jul 4, 2002 | 08:34 AM
PaceCarTN's Avatar
PaceCarTN
St. Jude Donor '03
Default Re: Vehicle Emissions Test Failure (smonska)
I think that means that the gas inlet has not been “punched-out” to allow the larger leaded gas hose to be used.
Old Jul 4, 2002 | 08:37 AM
PaceCarTN's Avatar
PaceCarTN
St. Jude Donor '03
Anyone know what this additive is? Any problems with using it?
Old Jul 4, 2002 | 06:47 PM
PaceCarTN's Avatar
PaceCarTN
St. Jude Donor '03
Old Jul 4, 2002 | 08:39 PM
TD-Machines's Avatar
TD-Machines
I seen that stuff at Pepboys here in pennsylvania. It was on the shelf right next to the Octain Booster.
Old Jul 5, 2002 | 04:11 PM
PaceCarTN's Avatar
PaceCarTN
St. Jude Donor '03
Default Re: Vehicle Emissions Test Failure (td-machines)
I passed!
Ran some SEAFOAM through it.
Reduced HC from 593 to 145 (Limit 400)
Reduced CO From 4.58 to 1.81 (Limit 4.00)
CO2 from 9.63 to 12.58
:) :smash: :smash: :) ;)
To Vehicle Emissions Test Failure
