Brakes delay return
Old Sep 30, 2013 | 04:39 AM
pvana's Avatar
pvana
Default Brakes delay return
Hi
my brakes are great, work perfectly. All is new except proportional valve. BUT after I release pedal - brakes are still in action and it takes about 1-2 seconds when they are fully released. Brake pedal aslo returns slowly - I have tried to help the pedal to come up with my other foot but I have felt a lot of resistance. Any idea?
Old Sep 30, 2013 | 07:03 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Lots of ideas but I don't think you'll like them
To begin with, is you brake fluid in the reservoirs clear and clean looking? When you say all is new, does that include the flexible brake lines that goto the calipers?
Old Sep 30, 2013 | 07:05 AM
CA-Legal-Vette
Another question, are you brakes manual, power or Hydroboost?
Old Oct 1, 2013 | 03:16 AM
pvana's Avatar
pvana
Power brakes, sorry!
Old Oct 1, 2013 | 08:47 AM
CA-Legal-Vette
Ok. The reason that I asked is that I've seen similar issues with Hydroboost.
Unless its totally gummed up, I find it hard to believe that the cause is the distribution block. I'd lean towards bad flex hoses.
Old Oct 1, 2013 | 11:19 AM
MelWff's Avatar
MelWff
You state all is new, does that mean a new master cylinder and if so are you sure you have the correct one? Where did you get it and what part#?
Old Oct 1, 2013 | 08:57 PM
1969Corvette's Avatar
1969Corvette
Your hoses are swelling shut not allowing the fluid to return. Don't buy cheap hose's or you will be doing it again in a few years. A good quality Goodyear hose is available on E-Bay in a kit for all 4 wheels.
Old Oct 2, 2013 | 02:44 AM
pvana's Avatar
pvana
Thank you very much for all your good ideas.
Yes master cylinder is new from Eckler´s part #46846
http://www.ecklerscorvette.com/corve...1968-1982.html
Also all brakes lines are new, steel and robber. All purchased from Eckler´s.
Brake fluid is reservoir is crystal clear but I have noticed it being quite dark in rear right brake caliper - so this suggest rear flex line going bad – even 18 months old. I guess you might be right about cheap replacement!
I guess I start replacing all flex lines and see what happens.
To Brakes delay return
