80 rear leaf link removal/replacement
Old Sep 30, 2013 | 02:53 PM
Maddan's Avatar
Maddan
Default 80 rear leaf link removal/replacement
Wondeing if anyone has an easy way to replace the rear leaf link bolts/cushions etc., got one end loose, but it scared the hell out of me...
Thanks, Dan
P.S. while I've got it loose, I'm going to try to change the pinion snubber...
Old Sep 30, 2013 | 02:57 PM
hugie82's Avatar
hugie82
A good floor jack under the spring and a ratchet strap for security works. You didn't just unbolt it.....did you???
Old Sep 30, 2013 | 03:36 PM
Maddan's Avatar
Maddan
No, i had bottle jack under 1 end, jacked it high enough to release tension then backed it off, thought about the strap AFTER it went sproing!!! (washers and bushings flying!!!)
Thanks, Dan
Old Sep 30, 2013 | 04:16 PM
MelWff's Avatar
MelWff
A lot safer using a floor jack and jack stands.
To 80 rear leaf link removal/replacement
