Im sure this is probally covered here more than once and I have used the search function and found some helpful info. Can I vertically mount the amps to the aft bulkhead or will the screws hit the fuel tank ?
Im thinking of using a peice of 1/4" wood or so and drill holes for the amps and run counter sunk machine screws from the back side. I can probally attach the wood to the bulkhead with adhesive.
You should always double check but there should be several inches of room behind that wall. Those pics are my 72, replacement tank but the correct size.
M
M
Thank you, my 72 coupe is the same color as yours. I am re-doing the interior with all new carpet and underlayment, new dash pad, all leather seat covers,new instrument cluster bezel ect.
