HO is 300 HP 1968 corvette engine with TH trans. Likely a 3.08 gear. This is a 10 to 1 comp engine with Iron heads. Your in that situation that your compression needs a bigger cam and your trans and rear end call for a smaller cam. Use this. Crane does not have the ground in advance of most and will handle more compression. The duration matches your RPM needed for city driving with your gearing. http://www.summitracing.com/parts/cr...make/chevrolet
You likely have had modifications, repairs, rebuilds done so it is hard to tell your compression and rear ratio now but this cam should be sweet and safe.
...Anybody: Are camel hump heads indicative of 350hp engine?...
No. The same heads were used on 300 and 350 hp 327s. Camel hump usually means bigger valves compared to other small block heads of the period.
Sapple89: HO indicates the base 300hp 68 327 with automatic transmission (TH400). If you found the engine stamp on the pad, it's likely the VIN derivitive is also there. Worth going back and looking for the second stamp.
Would that mean that it is unlikely to be an L79 or L46 as they would have 4-bolt mains?
No, there were no small blocks with 4 bolt mains until the 1969 model year. All small blocks from late 1954 (1955 model year) through the 1968 model year were 2 bolt.
I'm going to disagree with Mike on this one. Most "camel hump" heads were configured with 1.94" intake/1.50" exhaust valves. They were more common because the lower horse power engines were more common. The "camel humps" with the 2.02" intake/1.60" exhaust valves were only used in the high horse power engines (327/350 for example), and since there were a lot less of these engines made, there were a lot less of these heads used.
Ed
sapple89 - 63mako gives some very solid recommendations on camshaft choices - he gave me one for my 406 build - took me forever and a day to get the motors swapped, but now that I have, could not be happier with the engine. The power band is where I wanted it, and it's got the torque and power where I need it. Would not hesitate to follow his guidance.
The engine suffux code was stamped at the engine assembly plant and the partial VIN was stamped at the car assembly plant right before the engine was mated with the car. There should be another stamp on the front pad where you found the suffix code. Something like 18S123456 (as an example).
There is another way you can get a bore scope camera from harbor freight and remove a plug. If you can determine if you have flat top pistons or domed it will make your cam choice easier.
I think you can get the bore scope for a little over $100 with the 20% off coupon.
