Tips for Steer Box, Springs, Shocks?
1. Aside from every day tools that I have, what specialty or less common tools will I need? I’ve read about the pitman arm remover, pickle fork and possibly a spring compressor. What else do I need?
2. Can I remove the pitman arm from the steering box while it’s in the car? I don’t plan on replacing anything else below the box as the car just got a new power steering valve and some of the related pieces. The puller looks like it hits the center screw/nut/bolt? How do I put the pitman arm back on the new steering box? Do I use the puller to put it back on as well? I’ll probably have to buy another torque wrench since I think mine stops at 80 ft-lbs. As you can tell, I have not watched a video on this yet.
3. I’ve never done coil springs before. Can I use a 1.5 ton jack to accomplish many of the techniques I’ve read about on the forum or will the spring push my jack down to fast? It’s only about a year old (the racing jack from HF). I read about people cutting a ¼ coil and then more if necessary, how hard are these to cut? I’ve got a dremel-equivalent that usually cuts through metal adequately, but nothing like these.
4. Will I need to purchase new ball joints? I’ve never done this or used a pickle fork before, but will it damage the joints to where a new one is necessary? I was going to try and watch a YouTube video about this later when I get to the house.
Anything else I should definitely know? Any parts I should definitely add to the list? The car already has new rear camber rods. With the shocks I was going to buy some of the poly mount grommets to throw on since I’m taking them off anyway.
If anyone feels like writing up a hold-my-hand guide, I’ll take it! As always, thank you all in advance.
Wheel bearings also.
Condition of all spot welds and attached brackets for lower control arm mounting. I have seen numerous suspension cradles separated and spot welds broken due to accidents and other impact issues.
If the engine cradle is collapsing due to age and design...thus at your upper control arm attachment/alignment areas ( where the shims are located for alignment) there are either very few thin shims or no shims at all. SO the distance between the shaft in your upper a-am...and the perch where it mounts to the engine cradle is very, very close or touching due to NO SHIMS...you might need to either replace the upper control arm shaft with the aftermarket off-set design...or send your car out to a frame shop so they can stretch the cradle back into position so you can install shims and have years of alignment possibilities once again....or also have the "spreader-bar" installed so the upper A-arms can not move inward. ALL the spreader-bar does is hold these points in a set position....the spreader bar CAN NOT spread your cradle back.
DUB
In looking at the ball joints last night, at least the top joints, they look pretty darn good compared to what I expected. They've been replaced and are the bolted in kind. If I use the pickle fork will I only mess up the boot? I see that I can buy 4 boots from VBP for ~$10.
Do you know what size the pitman nut is? I thought I saw it on a post being much larger than any sockets I currently own, but haven't run across it again. I'll have to pick one up.
Where'd you pick up your spring compressor? VBP has a nice looking one, but it's also $70. It does still seem like a better deal than some of the cheaper ones I've seen though.
Thanks again!
Thanks again!
I have a Snap-on Spring compressor. I would be cautious on being a bargain hunter when shopping for this specific tool. It will be under a lot of tension...and that is not the time to be....ahhhh..."thrifty".
Places like O'Reilly's has a loan a tool. Give them some $$$$...use the tool...return it in the time allowed...and get all your money back. It won't cost you a thing.
DUB
