68 Hood is stuck
Old Oct 3, 2013 | 10:20 PM
Hub454's Avatar
Hub454
Default 68 Hood is stuck
I was adjusting the hood latch, closed the hood and now it is stuck. I can see through the side vent that the cable is fine. It looks like the latch on the cable missed the sticker and is stuck. Does anyone have any ideas to get it to release?
Old Oct 4, 2013 | 05:35 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Default stuck 68
the passenger side you can unbolt the three bolts that hold the base plate on. always wondered about the drivers side myself. I'll stay tuned to see how you do. Terry
Old Oct 4, 2013 | 08:59 AM
John 65's Avatar
John 65
If its a gm hood, unscrew the 8 screws from your wiper grill and remove it.
Get a long screwdriver and line it up with that "V"
Find and push on the tab and it will pop. You have to do a little fishing for it but will will find it. Came in handy for me several times.
Old Oct 4, 2013 | 02:50 PM
Hub454's Avatar
Hub454
Thanks John, you have given me hope. I was so frustrated I had to walk away. I will give it a try tonight.
Old Oct 4, 2013 | 04:38 PM
Alan 71's Avatar
Alan 71
Hi,
Here's a picture of the tool that's described in a Service bulletin.
I believe it's intent is to reach through the wiper grill without removing it.
Blow the picture up to 8 1/2"x11" to determine the tool's size.
Good Luck!
Regards,
Alan
Added: Sorry, now that I read the instructions again I see the tool applies to 70-72 cars. I guess the 68-69 cars didn't have the hole w/plug.
To 68 Hood is stuck
