Right side door jam switch 1977 corvette
Old Oct 5, 2013 | 08:16 AM
Ryder12's Avatar
Ryder12
Default Right side door jam switch 1977 corvette
I noticed that when I wiggle the right door jam dome switch the dome light flickers. Can someone tell me how to change that right door jam switch ??
Old Oct 5, 2013 | 09:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Does the courtesy light work when you open/close the door? If so, the switch is working and may not need to be replaced.
Old Oct 5, 2013 | 09:29 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Those are made with "loose" contacts. Like Mike said, if it ain't broke don't fix it.
Old Oct 5, 2013 | 11:39 AM
Ryder12's Avatar
Ryder12
Old Oct 6, 2013 | 04:37 AM
nz corvette's Avatar
nz corvette
Hi, if you need to get at the switch to check the wires, it's pretty simple, take the door sill off(4 screws) and then the foot kick panel, in my 77 there is 1 screw that holds it on up by the fuse box
cheers Dave
Old Oct 6, 2013 | 07:23 AM
Ryder12's Avatar
Ryder12
To Right side door jam switch 1977 corvette
