Need help wiring 4-pin style coil
Old Oct 6, 2013 | 07:12 PM
htown81vette's Avatar
htown81vette
Default Need help wiring 4-pin style coil
I purchased and installed the Holley Terminator EFI and was more or less happy with it. I was not satisfied that I could not control the timing (although it has these capabilities) so I bought the ECU controlled distributor much like the ones you find on 82-mid 90's GM cars. I also had to buy the 4 pin style coil. When I hooked it up the coil got very hot then started smoking. I took the coil back and got another one.
Here is how I had it wired the first time:
The Black connector was hooked directly to the module on the distributor.
The gray connector has 2 gray wires, one is larger than the other. I hooked the large gray wire to 12V +, then hooked the smaller gray wire to ground.
What did I do wrong?
Old Oct 6, 2013 | 08:13 PM
lionelhutz's Avatar
lionelhutz
That connector would be 1-wire to switched 12V and the other wire is for the tach. Don't ground it.
Old Oct 6, 2013 | 09:10 PM
htown81vette
Which one though? The bigger gray goes to switched 12V and the smaller gray to tach?
Thanks.
Old Oct 6, 2013 | 09:17 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thanks.
I would think it would be reasonably easy to ohm out the connections to see which wire does what. Have you tried that?
Old Oct 6, 2013 | 10:17 PM
htown81vette
There is no need to now. I wired it according to the lionel's post and it fired right up. Big gray went to 12V + and small gray left unhooked for now.
Now I can control the timing at idle, cruise, and wot by just adjusting the parameters in the handheld which is pretty trick..
Thanks!!
Old Oct 6, 2013 | 11:58 PM
lionelhutz's Avatar
lionelhutz
Good to hear you're running. I would've had to look it up but you could have tried either way. The logical way to test is the larger wire for power. I know I've crossed them before without damage but it just doesn't start so you were safe to experiment.
To Need help wiring 4-pin style coil
