72 center guage cluster
Old Oct 7, 2013 | 11:39 PM
craig marzec's Avatar
craig marzec
5th Gear
Default 72 center guage cluster
need pictures of the dis-assembly and assembly of a 72 center gauge cluster
Old Oct 8, 2013 | 07:36 AM
Alan 71's Avatar
Alan 71
Hi craig,
First Post!!! Welcome!!!
Do you mean getting the cluster out of the dash, or disassembling the cluster after it's out of the dash?
Do you have the Assembly Instruction Manual (AIM) for your 72?
Regards,
Alan
Old Oct 8, 2013 | 09:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Why are you wanting to take it apart? Are you asking how to remove it and reinstall it?
Do you have the assembly instruction manual (AIM) as Alan suggests?
Old Oct 8, 2013 | 01:17 PM
rberman999's Avatar
rberman999
As already stated you need a copy of the AIM for your MY. Also search the forum and you will likely find the answers you need. Finally, check out the Willcox web site as there are good instructions for the center instrument cluster removal. Lots of luck, Russ.
Old Oct 8, 2013 | 07:30 PM
craig marzec
5th Gear
i have dis-assembled it to replace the clock and i am unsure of how the lens goes back in - thanks
Old Oct 9, 2013 | 05:31 PM
craig marzec
5th Gear
Old Oct 9, 2013 | 05:46 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
To 72 center guage cluster
