Engine bay and suspension
Old Oct 8, 2013 | 03:06 PM
mk8035's Avatar
mk8035
Default Engine bay and suspension
1976 Vette have the motor out. What to install a 454 engine had a 350 before. First should i sand blast the engine bay or is there another way? Should i replace all the bushing and tie rods Etc? Is ther any kits i can buy to do this? Any help is a appreciated.
Old Oct 8, 2013 | 03:11 PM
MelWff's Avatar
MelWff
here is a kit, they have other choices too.
http://willcoxcorvette.com/product_i...ducts_id=25756
Old Oct 8, 2013 | 03:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mk8035
...should i sand blast the engine bay or is there another way?...
Why not just clean it? Steam cleaner or Simple Green and a brush. You want to remove the dirt and gook, not the paint.
Old Oct 8, 2013 | 04:20 PM
mk8035's Avatar
mk8035
There is alot of gunk but i guess i will give that a try first.
Old Oct 8, 2013 | 10:55 PM
7t9l82's Avatar
7t9l82
you would not believe the mess you would make sandblasting . on really heavy grease you can use oven cleaner, but be careful of your skin and paint.
Old Oct 8, 2013 | 11:08 PM
Mr.Green's Avatar
Mr.Green
Sandblasting won't work very well with grease and grime covered parts. The sand bounces off and doesn't have a chance to do the impingement damage it's supposed to do. Took a lot longer than it should have to figure that out!
Old Oct 9, 2013 | 06:32 AM
mk8035's Avatar
mk8035
Thanks allot for your answers.
Old Oct 9, 2013 | 10:45 AM
hugie82's Avatar
hugie82
Without the engine in the car, you'll need a spring compressor to lower the A arms. You might get a big surprise if you unbolt a ball joint with no weight holding the spring in place.
To Engine bay and suspension
