Valve covers
Old Oct 10, 2013 | 12:03 AM
hotrodnick's Avatar
hotrodnick
Default Valve covers
I would like to add aluminum valve cover to my 79 l48. I can not find ones with the three holes. Any suggestions? I need to do a tune up in the spring after storage, I plan to keep it stock, what gives the best performance for a stocker.
Old Oct 10, 2013 | 05:31 AM
Jig A Low's Avatar
Jig A Low
I assume you don't have the factory motor in the car? unless I'm mistaken (which is possible), you have 3 bolt valve covers you have Vortec heads on the motor---IF thats the case, you will need to look for valve covers specifically for the Vortec heads.
Old Oct 10, 2013 | 09:16 AM
Roughrider's Avatar
Roughrider
He said he has an L48, so it should have perimeter valve covers. If, in fact he does have Vortec heads and centerbolt valve covers, he can buy adapters to be able to use perimeter valve covers. These adapters are quite available and work well.
Old Oct 10, 2013 | 09:35 AM
MelWff's Avatar
MelWff
Regardless of what design cover you have there is no performance increase from aluminum valve covers.
Old Oct 10, 2013 | 09:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by hotrodnick
...I would like to add aluminum valve cover to my 79 l48...
Purchase a pair of stock, L-82 valve covers.
To Valve covers
